SHD2 SHO2
Intelligent Devices Forum
Schneider Electric support forum about all Intelligent Field Devices brands of Sensors, Thermostats, Glass Touch Panels, Valves and Actuators
  • EcoStruxure Building
  • Intelligent Devices
  • SHD2 SHO2
CraigEl
Administrator CraigEl Administrator
42
MikaelKrantz
Guinan MikaelKrantz Guinan
11
Gary
Gary Schneider Alumni (Retired)
11
Back to Intelligent Devices Forum
PiotrJakubczyk
Sisko PiotrJakubczyk Sisko
Sisko
Posted: ‎2024-06-17 07:19 AM . Last Modified: ‎2024-06-17 07:20 AM
671
SHD2 SHO2
Hi
Is same true for SHD2 and SHO2 as mentioned in this article:
https://community.se.com/t5/Building-Automation-Knowledge/SHD-SHO-SHR-humidity-sensor-series-specifi...
It would be strange if outside humidity sensor can't recover from 100% humidity.
  • Temperature Humidity & Air quality Sensors
CraigEl
Posted: ‎2024-06-17 05:24 PM
@PiotrJakubczyk yes, the same is true, however it would be extremely unlikely that you will ever measure 100% RH since the formation of dew on the sensor will effectively cause some moisture to be removed from the air. It is also noted in the article that condensing won't damage the sensor so it will "recover from 100% humidity".
CraigEl
