Usb PLC Driver in Windows 10 and 11
  • Industrial Automation
  • Usb PLC Driver in Windows 10 and 11
Bastian_Schmitz
35
LeTomas
14
JerryBartlemay
7
EcoStruxure™ Control Expert
brianhodgert
brianhodgert
Cadet
Posted: ‎2022-09-09 01:48 PM
10086
My PLC USB driver isn't working in Windows 10 and 11. It works in earlier versions. Things checked:
  • I have updated to the latest drivers.
  • Event viewer shows "CoId={3BD2E028-BA74-4A29-B628-E1E2570F2F5D}: The user SYSTEM dialed a connection named USBCON which has failed. The error code returned on failure is 797."
  • in Device Manager the BMX CPU shows "Opening the modem device failed with error 00000020" in the diagnostics
  • Usb PLC is running in Services
  • ControlExpert message is "This isnt a vailid PLC Address, or PLC is busy, or media is off."
  • Connected Products
Robert_Willis
Lieutenant JG Robert_Willis Lieutenant JG
Lieutenant JG
Posted: ‎2022-09-09 07:24 PM
10074
Questions:
1. What PLC are you connecting to?
2. What programming software ae you using?
3. What version of the driver are you running?
brianhodgert
brianhodgert
Cadet
Posted: ‎2022-09-12 09:51 AM
In response to Robert_Willis
1.) Connecting to M340
2.) Using ControlExpert
3.) Latest version of the driver from Schneider Setup Version 14.15.0.0
Rajesh7
Rajesh7 Cadet
Cadet
Posted: ‎2025-08-27 12:04 PM . Last Modified: ‎2025-08-27 12:06 PM
My PLC is connected to windows 10 device with cable tsxcusb485, communication worked when the PC was in windows 10, i have upgraded the OS to windows 11 through windows update option, after the upgradation the communication is not working' - PLC TM200CE40R
i need support to  - 9916056016
email :- rajesh.sk@se.com
