Posted: 2025-08-22 06:44 AM
I need to equip the LUB32 with LUCB32FU and both fault contacts NO 97-98 and NC 95-96. Is this possible?
Posted: 2025-08-27 12:06 AM
Hi PantheraInAutomation,
As these contacts exist on separate modules, you cannot use them together on the same starter.
You can use function module LUFDH11 which will provide you with a normally open and normally closed thermal overload fault contacts. Please not this module will require a separate voltage supply.
Posted: 2025-08-27 11:50 PM
Hello Mr. DuMalt,
Thank you for your tip... that will do the trick.
Sincerely yours,
PantheraIA
