TROUBLESHOOTING old modicon plc.
  • Industrial Automation
  • TROUBLESHOOTING old modicon plc.
Bastian_Schmitz
35
LeTomas
14
JerryBartlemay
7
Rishi1
Crewman Rishi1
Crewman
Posted: ‎2022-08-07 11:43 PM
4896
I want to communicate and diagnose the fault appearing in the plc,through software.
Its modicon TSX premium.I Want to know
-   what is the setup required for communication
    which is the software,os,communication cable etc.
in my plc rack i have modules TSX PS7303A , TSX ETY4103 with this how can i connect with pc
- TSX PS7303A is having rs232 round pin i assume ,i dont have the cable.if i get the pinout i can make the cable myself.
-  TSX ETY4103  this module is having ethernet port but i dont know the ip address or how to establish communication.
please check the attached image for details
modicon.rar
  • Asset Performance
  • Connected Products
  • Edge Control
  • Hybrid DCS
RoozeeR
Lt. Commander RoozeeR Lt. Commander
Lt. Commander
Posted: ‎2022-08-08 12:18 AM
Hello Rishi,
1: This Modicon premium CPU is probably programmed with PL7. PL7 is no longer available for download since 2018 as it's in service mode. So you need someone who can provide you a copy. Could also be programmed with the current UnityPro/EcoStruxure Control Expert software, is this particular CPU type could be upgraded with new firmware. This is not shown by the Partnumber of the CPU, as this is a just a firmware upgrade. You need the application file or some other information from the owner showing this.
2: If you want to diagnose/debug the application you need a copy of the original application. If you're lucky you can upload this application form the CPU, but only if the original program was transferred including the upload information. If this was transferred without upload information, you need the original application file.
3: The TER port is an RS485 port. Easiest to use this, is using the original cable which includes an RS232/RS485 converter. Do not start building your own. Also these cable sets are no longer available for sales.
4: Connect to the ethernet port on the TSXETY4103 module. If you do not know the IP address (available in the original application file) you can try to connect your laptop to the Ethernet port and use WIRESHARK (free download). At powerup, the ETY module will send some "Gratious ARP" messages showing it's IP address.
5: You need to install XWAY drivers (part of PL7 programming package) to communicate with the CPU through Ethernet and through the TER port.
My advice:  Find someone who has experience and the (application) software, or ask your local Schneider Electric service organization.
R.Roozee
Sr Solution Architect (SAE Master)
RoozeeR
Lt. Commander
Hello Rishi,
R.Roozee
