Ethernet Switch Configurator Program (2.3.03)
  • Industrial Automation
  • Ethernet Switch Configurator Program (2.3.03)
Bastian_Schmitz
35
LeTomas
14
JerryBartlemay
7
Windsor
Lt. Commander Windsor Lt. Commander
Lt. Commander
Posted: ‎2021-05-19 07:13 AM
8140
I am trying to access the web server of a ConneXium switch (TCSESM083F2CS0) using Internet Explorer on a laptop running Windows 10 build V20H2 (OS Build 19042.804). After connection to the switch the following error message occurs: ClassNotFoundException com_schneider_electric.products.Applet. The laptop has the 32 bit version of Java 8 Update 291 installed.
Any ideas appreciated.
  • Connected Products
Alpenglow
Ensign Alpenglow
Ensign
Posted: ‎2021-05-19 07:56 AM
2
8131
I did this somewhat recently.  I had similar issues.  What I had to do to get it working was use Internet Explorer 11 with Java v8 runtime 281.  This was also all inside of a WIN7 VM.
The good news is that all of the new Modicon switches are configured via HTML5 instead of Java.
Blue side up.
Replies 4
Alpenglow
Ensign Alpenglow
Ensign
2
8132
Blue side up.
Windsor
Lt. Commander
Posted: ‎2021-05-19 09:39 AM
In response to Alpenglow
Thanks for the quick response @Alpenglow. All I needed to do was download and install the 32 bit version of JRE 8 281 and problem solved!
Posted: ‎2021-06-04 04:57 AM
@Windsor wrote:
I am trying to access the web server of a ConneXium switch (TCSESM083F2CS0) using Internet Explorer on a laptop running Windows 10 build V20H2 (OS Build 19042.804). After connection to the switch the following error message occurs: download
thanks for posting about this it heled me thanks
RogerC
RogerC
Cadet
Posted: ‎2022-08-09 01:01 PM
Thanks for this solution. This exact combination works whereas many other combinations of Windows/ IE and Java versions that I had tried beforehand didn't. This setup also works with Advantys STB which has similar issues.
