STB and DDT equipment
  • Industrial Automation
  • STB and DDT equipment
Bastian_Schmitz
35
LeTomas
14
JerryBartlemay
7
Schneider
Unity M580 Application Converter
Posted: ‎2021-08-12 07:13 AM
1397
Hello
The documentation says that the modules are identified by their position in the island which is therefore used to generate an "ID" + position.
I have the configuration below
STBSTB
When it is integrated via the DTM in unity pro, I recover from the following equipment DDT where it can be seen that the "IDs" do not correspond at all to the position of the module.
DDT STBDDT STB
I don't understand why ?
I use Unity pro  V12  and advantys
  • Smart Design & Engineering
Rodrigo_Garcia
Commander Rodrigo_Garcia Commander
Commander
Posted: ‎2021-10-20 02:35 AM
1321
Hello @YoramG , do you know support on this? Thanks!
Rodrigo G.
Industrial Automation Community manager
YoramG
Crewman YoramG Crewman
Crewman
Posted: ‎2021-10-21 08:18 AM
In response to Rodrigo_Garcia
Hello @Rodrigo_Garcia , sorry not heard about this
I suggest to submit this to Schneider Electric Expert support you will get the answer.
I m sure you will get answer
DarrellWrublesk
Crewman DarrellWrublesk
Crewman
Posted: ‎2021-10-21 09:04 AM
Did you remove modules from the initial configuration or have you made any changes to the configuration?  if you do that then the IDx will not line up.  if you create a USER Defined label within Advantys rather than allowing Unity to create the variable for you then the Variable will always line up with the slot you are using.
