Posted: 2025-11-25 02:00 AM
Dear All,
is there anyone can help me ?
i want to use M221 as Modbus Serial Gateway
is it possible ?
and how to do it ? because i'm not succeed yet
Posted: 2025-11-25 10:31 AM
The M221 PLC has one RS-485 Modbus port. Using this port, you can read data from Modbus slave devices and assign the values you read to the internal registers of the TM221.
In the system, a client can also treat the TM221’s Ethernet port as if it were a slave (server) device, and the TM221 will serve its own registers to that client.
However, to do this, you need to write a small amount of code as described above.
It cannot be used as a gateway with only configuration settings like a typical off-the-shelf gateway device. Still, it can function like a gateway as long as the system requirements and limitations are taken into account.
Posted: 2025-11-25 10:20 PM
Dear @ismailozinan
Thank you for your info,
but i still cannot actually succeed to pull data from my field device
this is the screenshot
is there anything wrong with it ?
can you help me ?
