ATV630D18N4 Firmware update failure
  • Industrial Automation
  • ATV630D18N4 Firmware update failure
Bastian_Schmitz
35
LeTomas
14
JerryBartlemay
7
tiago_angelo
Crewman tiago_angelo
Crewman
Posted: ‎2024-05-16 11:32 AM
2404
Good evening, I have an ATV630D18N4 and decided to update its firmware..
Original firmware is/was 2.5IE30B10, target is the latest version from Schneider 3.8IE42B05, I'm already using the latest version of Automation Device Maintenance and added the two certificates that are referred here:
https://www.se.com/ie/en/faqs/FAQ000256127/
I'm connected over Ethernet.
On the logs I get this:
5/16/2024 7:13:18 PM Opened connection to device [10.50.4.101]
5/16/2024 7:14:24 PM Starting firmware download
5/16/2024 7:14:24 PM Transferring firmware 0/72
5/16/2024 7:18:33 PM Transferring firmware 71/72
5/16/2024 7:18:33 PM Firmware transfer complete: Disconnect success
5/16/2024 7:18:33 PM Applying firmware update, please wait a few minutes
5/16/2024 7:18:33 PM Do not press any key on the display terminal, until the Apply operation is completed
5/16/2024 7:18:36 PM Firmware update status changed: SAVE >> 36
5/16/2024 7:18:36 PM Firmware update is ongoing
5/16/2024 7:18:36 PM Do not press any key on the display terminal, until the Apply operation is completed
5/16/2024 7:18:45 PM Firmware update status changed: PROG >> 36
5/16/2024 7:18:45 PM Do not press any key on the display terminal, until the Apply operation is completed
5/16/2024 7:18:45 PM Firmware update application failed
5/16/2024 7:18:45 PM Load sequence failed with message (5) ERROR_OPERATION_FAILED (Message: )
I have already power cycled the drive, but its now stuck in the failed firmware update error.
What can I do, is it possible to have the original firmware files and try to flash them instead?
Best regards.
  • Process Automation Talks
  • ATV630
  • firmware
Replies 8
Bastian_Schmitz
Admiral
Posted: ‎2024-05-26 11:49 PM
3
2348
Hi I have forwarded per E-Mail an invintation to a onedrive link were you could find all FW Versions.
So far I see you need first to update to an earlier version then v3.8. But I´m not a specialist in this topic. Please contact your local Level 2 support. I would expect they could support you by this topic.
tiago_angelo
Crewman
Posted: ‎2024-05-27 08:29 AM
2
2334
Thanks Bastian_Schmitz.
I will try an older version of the firmware, if I can't solve it I will contact my local Schneider support.
Best regards!
Hammer
Hammer Cadet
Cadet
Posted: ‎2024-06-26 09:23 PM
In response to tiago_angelo
2270
Hi.
I encountered the same problem now. 🙂
How did you solve it?
CB1
CB1 Cadet
Cadet
Posted: ‎2024-12-18 11:48 AM
In response to Bastian_Schmitz
Hi Bastian ,
I am also now stuck in the failed firmware update error.
What can I do, is it possible to have the original firmware files and try to flash them instead?  Could you send me the old FW versions also.   Also how do I contact "Local Level 2 Support?" Thanks
CB1
CB1 Cadet
Cadet
Posted: ‎2024-12-18 11:49 AM
In response to Hammer
Were you ever able to get out of the firmware update , if so how?   Thanks
Bosswaffle
Lt. Commander Bosswaffle
Lt. Commander
Posted: ‎2025-01-14 04:52 PM
@Bastian_Schmitz Could I get a link to all of the current firmware for ATV630U75N drives? I have 2 drives stuck at 3.7, and I'm trying to upgrade to 4.1
Jacob_AET
Jacob_AET
Cadet
Posted: ‎2025-11-25 05:42 PM
Hi Bastian,
Can i please get a copy of the link to al the FW.
Thanks.
Bastian_Schmitz
Admiral
Posted: ‎2025-11-26 02:10 AM
He please donwloaded this tool LINK
And then contact your local Support. They could forward the Firmware file. Not any firmware is compatible to any Hardware revision of the drive. But the local support should have the visibility
