ControlExpert 16.1 error opening project
  • Industrial Automation
  • ControlExpert 16.1 error opening project
Bastian_Schmitz
35
LeTomas
14
JerryBartlemay
7
Elvis_91
Crewman Elvis_91
Crewman
Posted: ‎2025-02-15 08:31 PM
1466
I am trying to open a project exists with v.15.0 with the software controlExpert v16.1 I get this error from the image.
What can I do?
Thank you
  • Connected Products
  • Process Automation Talks
Ricard
Lt. Commander Ricard Lt. Commander
Lt. Commander
Posted: ‎2025-02-17 11:41 PM
Hello @Elvis_91 ,
The software always uses the "DTM Audit Tool" to check the DTM/EDS versions of the project you just opened. If the "DTM Audit Tool" window appears, it means that it has found a discrepancy between these DTM/EDS elements compared to the "Hardware Catalog" available on the PC.
This usually happens when...
A "STA file" project is opened that was created in other versions of Control Expert
A project is opened with the same version of Control Expert but the "Hardware Catalog" is not the same, e.g. EDS/DTM files are missing or the Schneider DTMS versions are different due to a Control Expert update (HotFix).
Obviously, if we have version discrepancies with the same CE, we should update the HF or if we are missing the EDS/DTM we should install them.... For other cases like yours we should update the versions of the Project DTMs by following the steps below....
1-  In the DTM browser, click on the HOST PC and go to "DTM Service"
2-The following window will appear showing the versions of the project's DTMs and those we have in our "Hardware Catalog". We see that the versions aren't the same.
3- We select the devices we want to update and click "Update DTM devices"
4- Now we will have updated the project DTMs with the same version that we have in the "Hardware Catalog" of our PC.
Additional information:
https://community.se.com/t5/Modicon-PAC-Forum/DTM-Audit-Tool/td-p/198516
https://www.youtube.com/watch?v=w5USAikCHuw
BR
Ricard
Elvis_91
Crewman Elvis_91
Crewman
Posted: ‎2025-02-24 08:01 AM
Thank you. @Ricard
I followed the steps and it worked
