DTM Audit Tool
Modicon PAC Forum
Select a Country
  • Industrial Automation
  • Modicon PAC Forum
  • DTM Audit Tool
Trinxs1
Trinxs1 Leader
19
YONGHO-KIM
YONGHO-KIM Mentor
10
ciupol
ciupol
9
Back to Modicon PAC Forum
Trinxs1
Trinxs1 Leader
Leader
Posted: ‎2020-06-03 08:19 PM . Last Modified: ‎2024-01-24 11:50 PM
15
18584
DTM Audit Tool
Have you recently updated a Drives DTM and then opened an older project and see that the DTM Audit Tool identifies a difference in the DTM used in the project and the DTM on the PC?
How do you update the DTM in the project?
1.  Remove and reinstall the device in the DTM browser.  Not a good option as this requires capturing the configuration details and re entering them.
2.  Change the IP address of the device instance.  Build the project and change the IP address back to the original IP address.
This is very easy to do and will also update the DTM version.  However when you have fifty instances configured this is very tedious.
3.  Close the project and re open it.  The DTM browser will run but not highlight any differences and hence will not show.
What does not work...
Export the project and re import it.
Action to date: (updated 2024 01 25)
EcoStruxure Control Expert V16.0 now has a feature for you to be able to selectively update DTM versions.  Please note though that only one DTM version can be installed on your PC.  Which instances of a specific DTM you choose to update are up to you.  As long as the version of the DTM installed on your machine is equal to or later than the one used in the project life is ON!
Trinxs
Senior Technical Sales Consultant - PAC
  • 01. Modicon M340 PAC
  • 02. Modicon M580 ePAC
  • 03. Modicon PAC Safety
  • 06. EcoStruxure Control Expert
Replies 15
GeoffChisholm
GeoffChisholm
Troubleshooter
Posted: ‎2020-10-08 03:53 PM
2
18573
It would be good if the Audit tool or Unity had an option to update the DTM versions within the project
Posted: ‎2021-01-14 11:04 PM
In response to GeoffChisholm
1
18352
Fully agree, tool or option in Uniti Pro will be the best solution!
Gabz
Gabz
Explorer
Posted: ‎2021-05-18 06:53 PM
In response to Anonymous user
why is this marked as solved?  is there a tool? to do it or are you stuck changing IP address on things (which doesn't appear to work for me)
Robert_Willis
Robert_Willis Troubleshooter
Troubleshooter
Posted: ‎2021-06-24 12:30 PM
This is NOT a solution as in some industries modifications of this type after the FAT / SAT would require them to be documented, validated, FAT and SAT completed. We need a solution that allows the user to select the option to update the DTM from the DTM Audit Tool and to explain if a Build or Rebuild all is required.
dnordenberg1
dnordenberg1
Explorer
Posted: ‎2022-10-19 08:13 AM
Yes please make an option for letting ESCE updating the project DTM versions so we don't have to do it manually in messy ways but it should not be done by default without user authorization
Ricard
Ricard Troubleshooter
Troubleshooter
Posted: ‎2023-09-06 12:44 AM
14870
Hello every one,
One of the improvements that the Control Expert 15.3 has made is the introduction of a DTM updater utility in the CE's own DTM browser.
Update Application project with newer device DTM version
Device Management – Control Expert Classic & Topology Manager
I'm Attaching the following steps that how to update the DTM easily
User can compare device DTM version used in the opened Project with device DTM version present in the PC.
Update of one or several devices DTM is possible by doing the following actions :
·        Select DTM Brower > Right Click on Host PC > DTM Service…
·        Select Device to update using check box
·        Click Update DTM devices button
The topology manager also offers this new feature:
Note 1: only one version of a Device DTM is installable on a computer. So if you decide to not update your devices with the same version, when you will open device and save the device will be automatically saved with the PC installed DTM version.
I hope my comment is useful for you
Good luck!
Ricard
ciupol
ciupol
Mentor
Posted: ‎2023-09-27 05:40 AM
I have used the tool above and unfortunately is has dome bugs. It does not report all DTMs versions correctly. The DTM versions in this tool do not match versions in DTM Audit Tool.
I have case with support about this and they were able to replicate my problem. The are working on solution.
SamCG
SamCG
Explorer
Posted: ‎2024-01-23 03:05 AM
I use the DTM service utility to update my DTMs.
It works very well except for one type of equipment: STB N I P
I have version 12.3 on my PC and 12.2 used in the project.
However, the utility sees version 1.x 2.x 3.x 4.x (hardware version) and notes that the hardware versions correspond. so no update...
Deleting and creating new equipment does not suit me.
Export from the DTM is possible but no import.
Do you have a solution ?
THANKS
ciupol
ciupol
Mentor
Posted: ‎2024-01-24 05:17 AM
In your DTM browser right click on the problematic device and select properties. Make sure there that the versions are different. For me the DTM service utility was reporting incorrect versions but in the properties window they were correct.
If you truly have mismatched versions I usually only change IP address, build changes, change IP address again to the original one, build changes again, and the versions are matched. No need to delete and recreate device DTM.
Muzza64
Muzza64
Explorer
Posted: ‎2024-07-16 08:51 PM
In response to Ricard
It only does SOME DTMs.... NOC? Forget it.  CPU?  Forget it.  Even the 'Change IP Address' fix only works sometimes.  Schneider - the master of giving you more 'undocumented features' than you imagined possible.
mohghazaly
mohghazaly Explorer
Explorer
Posted: ‎2025-09-14 12:36 AM
7078
I just need a clarification:
If the DTM version installed on my PC is earlier/older than the one used in the project, what is the recommended action?
dnordenberg1
dnordenberg1
Explorer
Posted: ‎2025-09-20 01:54 PM
In response to mohghazaly
What version of control expert do you have? Those DTM comes with control expert so I guess someone with a newer control expert upgraded them. Good question, never really thought about what happens when this occurs... I don't think there is a way to downgrade, So if you can't upgrade your control expert I guess you could export the code, create a new project with same DTM setup and import the code into the new project but I guess it would be better to upgrade control expert. When you open a project you can see what version was used last time it was saved when you click on a project file.
Farzad_Samimi
Farzad_Samimi Contributor
Contributor
Posted: ‎2025-09-23 05:06 AM
6899
For Unity or CE version before 15.3 you can use the method explained in this document.
dnordenberg1
dnordenberg1
Explorer
Posted: ‎2025-09-27 08:43 AM
In response to Farzad_Samimi
Don't think that will downgrade the version and not sure it will work for the CPU DTM either.
Ldonate
Ldonate Explorer
Explorer
Posted: ‎2026-09-08 09:45 PM
Thanks! happened to me just now!
