Cooling Optimize Benchmark report
ITA: Cooling Optimize (on-premises only)
  • EcoStruxure IT Help Center
  • IT Advisor
  • ITA desktop client
  • ITA: Cooling Optimize (on-premises only)
  • Cooling Optimize Benchmark report
  • Mark as Read
  • IT Advisor: Cooling Optimize
  • IT Advisor: Cooling Optimize system requirements
  • Configure Cooling Optimize integration
  • Configure the Cooling Optimize web client
  • Cooling Optimize Temperature Compliance report
EcoStruxure IT Support
Request Support
Back to ITA: Cooling Optimize (on-premises only)
  • Mark as Read
Sisko JLehr Sisko
‎2023-09-15 07:19 AM
on ‎2023-09-15 07:19 AM
A benchmark report can be created to compare the energy usage for a before and after time period. The report can be generated for each room and for the site total.
Power savings are quantified via power monitoring on the controlled cooling units.
Calculated chiller power is included in the savings values for chilled water units.
Greenhouse gas reductions are calculated based on the following default conversion rates: 1.32 lbs./kWh and 0.59 kG/kWh.
The report is available from Analytics > Reports if you have a valid IT Advisor: Cooling Optimize license.
Filter selections
  • Baseline time period
  • Verification time period
  • Cost per kWh
  • Currency
  • Chiller coefficient of performance (COP)
idea_icon.png Create a report with your baseline measurements so they are easy to retrieve.
