Configure Cooling Optimize integration
ITA: Cooling Optimize (on-premises only)
  • EcoStruxure IT Help Center
  • IT Advisor
  • ITA desktop client
  • ITA: Cooling Optimize (on-premises only)
  • Configure Cooling Optimize integration
  • Mark as Read
  • IT Advisor: Cooling Optimize
  • IT Advisor: Cooling Optimize system requirements
  • Configure the Cooling Optimize web client
  • Cooling Optimize Benchmark report
  • Cooling Optimize Temperature Compliance report
EcoStruxure IT Support
Request Support
Back to ITA: Cooling Optimize (on-premises only)
  • Mark as Read
Sisko JLehr Sisko
‎2023-09-14 02:16 PM
Configure user credentials to allow IT Advisor: Cooling Optimize to communicate with Vigilent and receive cooling and temperature data.
  1. Go to System Setup > External System Configuration.
    1. Click Add ITA Coolin Optimize integration add.png and select IT Advisor: Cooling Optimize as the system type.
    2. Type the server identification: name, IP address, port.
      Add the API Token.
      The API Token allows secure communication with the Cooling Optimize server. The API Token can be created in the Cooling Optimize CX tool by a user with administrator rights.
  2. Click Test to verify the connection.
    If you are unable to launch Cooling Optimize, verify that an ITA user exists on the Cooling Optimize server.
  3. Verify the Polling interval.
    Note: Check Proxy Launch to device through IT Advisor server only if the Cooling Optimize Server is on another network and you must use the IT Advisor server as a proxy because there is no direct access to the Cooling Optimize server.
  4. Associate the devices found in Planning > Device Association > Cooling Optimize to the servers and CRAC units representing them in the floor layout.
  5. Verify that the data has been associated to servers and CRAC units.
