Configure the Cooling Optimize web client
ITA: Cooling Optimize (on-premises only)
  • EcoStruxure IT Help Center
  • IT Advisor
  • ITA desktop client
  • ITA: Cooling Optimize (on-premises only)
  • Configure the Cooling Optimize web client
  • Mark as Read
  • IT Advisor: Cooling Optimize
  • IT Advisor: Cooling Optimize system requirements
  • Configure Cooling Optimize integration
  • Cooling Optimize Benchmark report
  • Cooling Optimize Temperature Compliance report
EcoStruxure IT Support
Request Support
Back to ITA: Cooling Optimize (on-premises only)
  • Mark as Read
Sisko JLehr Sisko
‎2023-09-15 07:21 AM
In the Cooling Optimize web client, you can edit the temperature set points used for cooling control and turn the cooling units on and off.
User rights are required to launch to the Cooling Optimize web client.
Go to System Setup > User Rights and Authentication > Launch to Cooling Optimize > Save and close.
To launch the web client, go to the right-click menu of any Cooling Optimize item and select Launch to Cooling Optimize.
You can view and change the temperature set points of your racks in the Set Points tab.
The Equipment tab shows the state of the equipment, for example, cooling rate, power usage, and origin of on/off control. You can manually override units in the facility and turn your cooling units on and off.
