M172 Simulation
HVAC and Pumping Forum
Select a Country
  • Industrial Automation
  • HVAC and Pumping Forum
  • M172 Simulation
FedericoM
FedericoM Mentor
119
Bastian_Schmitz
Bastian_Schmitz Champion
64
M_Cervati
M_Cervati Troubleshooter
18
EcoStruxure™ Machine Expert - HVAC
POPE3909
POPE3909
Explorer
Posted: ‎2023-10-03 04:08 PM
1454
M172 Simulation
Hi Guys,
It's great to be back after the Spam cleanup.
I have a question regarding M172/EcoStructure HVAC. Is there a way to add expansion modules or simulate the I/Os from the expansion modules in the simulation?
  • Connectivity
  • HVAC
FedericoM
FedericoM Mentor
Mentor
Posted: ‎2023-10-05 02:15 AM
Expansions can't be simulated.
The workaround is a program which copies physical input defined in the field section into global variables to be used in the entire project.
This copy physical to logic should be enabled through an IF NOT(xSim) THEN... in this way when simulator is running you can set xSim and force the values of logical input from the watch window.
FedericoM
FedericoM Mentor
Mentor
