M172 Simulation
HVAC and Pumping Forum
  • Industrial Automation
  • HVAC and Pumping Forum
  • Re: M172 Simulation
FedericoM
Commander FedericoM Commander
77
Bastian_Schmitz
Admiral Bastian_Schmitz Admiral
52
LeTomas
Lt. Commander LeTomas Lt. Commander
14
POPE3909
Ensign POPE3909
Posted: ‎2023-10-03 04:08 PM
1034
M172 Simulation
Hi Guys,
It's great to be back after the Spam cleanup.
I have a question regarding M172/EcoStructure HVAC. Is there a way to add expansion modules or simulate the I/Os from the expansion modules in the simulation?
  • Connectivity
  • HVAC
FedericoM
Posted: ‎2023-10-05 02:15 AM
Expansions can't be simulated.
The workaround is a program which copies physical input defined in the field section into global variables to be used in the entire project.
This copy physical to logic should be enabled through an IF NOT(xSim) THEN... in this way when simulator is running you can set xSim and force the values of logical input from the watch window.
Reply 1
FedericoM
This is a heading
