M172 EEPROM Variables
HVAC and Pumping Forum
Select a Country
  • Industrial Automation
  • HVAC and Pumping Forum
  • M172 EEPROM Variables
FedericoM
FedericoM Mentor
119
Bastian_Schmitz
Bastian_Schmitz Champion
64
M_Cervati
M_Cervati Troubleshooter
18
EcoStruxure™ Machine Expert - HVAC
POPE3909
POPE3909
Explorer
Posted: ‎2023-10-31 03:29 AM
1832
Hi Guys,
I've got M172 on the site which would randomly lose its default EEPROM variables values with some random numbers taking place instead.
For example, in the EEPROM variables, I have set the default Temperature setpoint of '35' with minimum of 10 and maximum of 50, which is adjustable from the HMI. However, a random number of '1728' is found when I do live debugging.
What would be the likely cause this behaviour? Will a low RTC battery cause similar issue?
  • HVAC
FedericoM
FedericoM Mentor
Mentor
Posted: ‎2025-02-17 07:50 AM
This behaviour is for sure not related to RTC.
You might have a wrong pointer in the application.
EEprom is update only from serial access or by using functions sysWritePar*().
If in case of reboot the value is restored to the expected one, it should be a wrong pointer.
FedericoM
FedericoM Mentor
Mentor
