TM171VEVM4 Download not working
HVAC and Pumping Forum
Select a Country
  • Industrial Automation
  • HVAC and Pumping Forum
  • TM171VEVM4 Download not working
FedericoM
FedericoM Mentor
119
Bastian_Schmitz
Bastian_Schmitz Champion
64
M_Cervati
M_Cervati Troubleshooter
18
soonhyun
soonhyun
Explorer
Posted: ‎2024-12-10 10:59 PM . Last Modified: ‎2024-12-10 11:04 PM
1758
Hello
I am using Schneider EEV controller TM171VEVM4.
My program's firmware is 589.20.
Previously, the download was normal in 589.20,
but the firmware of the device was updated, and the download function of the device with the default value of 589.22 does not work.
1. Is it because of the firmware that it is not downloading?
2. The Read Parameters and Write Parameters icons at the top worked normally and I entered the data, and I changed AI4 to Disable, but the AI4 alarm appears in the alarm details.
And I tried to find the firmware 589.22, but I can't find it.
Even in the latest version, 1.7.0, it is still marked as 589.20.KakaoTalk_20241211_155026238.png
SCW1REV03.zip
  • HVAC
  • hvac
  • TM171
  • TM172
FedericoM
FedericoM Mentor
Mentor
Posted: ‎2025-02-17 07:40 AM
have you tried to set dL33 as not used?
Download All does not really make sense in case of TM171VEV, this command is related to programmable controllers, TM171VEV is a parametric one.
