M172 Check status of BACnet communication
HVAC and Pumping Forum
Select a Country
  • Industrial Automation
  • HVAC and Pumping Forum
  • M172 Check status of BACnet communication
FedericoM
FedericoM Mentor
119
Bastian_Schmitz
Bastian_Schmitz Champion
64
M_Cervati
M_Cervati Troubleshooter
18
EcoStruxure™ Machine Expert - HVAC
sardila
sardila
Contributor
Posted: ‎2022-10-20 07:30 PM
2350
Hi All,
I have successfully implemented BACnet (MSTP/IP) on M172. I just need to stop my application whenever the communication fail or lost connection.
How could I check  Acknowledge attribute?
I set already APDU_Timeout and the number of APDU admited.
Thanks in advance for your time!!!
Cheers
  • HVAC
sardila
sardila
Contributor
Posted: ‎2022-10-24 03:01 PM
In response to FedericoM
Many thanks!
Replies 4
FedericoM
FedericoM Mentor
Mentor
Posted: ‎2022-10-20 11:56 PM
2341
at the moment it is not possible in a native way.
With the coming bios version you'll have a new target variable which counts the number of Poll for Master and Reply to Poll for Master received by M172 which could be used for this purpose.
M172 will have also a counter for messages received via BACnet/IP and the IP of the last received message.
sardila
sardila
Contributor
Posted: ‎2022-10-23 03:03 PM
2295
Thanks for the update. When do you think the new Bios version will be released?
FedericoM
FedericoM Mentor
Mentor
Posted: ‎2022-10-23 11:48 PM
In response to sardila
2281
I think it will be released in December, unfortunately we had a delay in the production of a new product linked to the release of ESME HVAC 1.5.0
sardila
sardila
Contributor
Many thanks!
