How to activate TM5NEIP1 Web server ?
HVAC and Pumping Forum
Select a Country
  • Industrial Automation
  • HVAC and Pumping Forum
  • How to activate TM5NEIP1 Web server ?
FedericoM
FedericoM Mentor
119
Bastian_Schmitz
Bastian_Schmitz Champion
64
M_Cervati
M_Cervati Troubleshooter
18
ibdoumbiah
ibdoumbiah Explorer
Explorer
Posted: ‎2022-10-24 10:46 AM
1301
I need some reponses about TM5NEIP1:
1- How to activate the web server of TM5NEIP1.
2- Is it possible to configure TM5NEIP1 via Machine Expert without using a controleur ?
  • Connectivity
KJBER
KJBER
Contributor
Posted: ‎2022-10-25 01:11 AM
1. The Web server is disabled by default. The Web server can be enabled or disabled through
the EcoStruxure Machine Expert software, see picture
2. Not that I know off, I had to have a controller and use the default IP adress to the TM5NEIP, then after I was able to enable webserver, then I could change the IP adress via WEB.
