BACnet Addons Library for Ecostruxure Machine Expert HVAC
HVAC and Pumping Forum
Select a Country
  • Industrial Automation
  • HVAC and Pumping Forum
  • BACnet Addons Library for Ecostruxure Machine Expert HVAC
FedericoM
FedericoM Mentor
119
Bastian_Schmitz
Bastian_Schmitz Champion
64
M_Cervati
M_Cervati Troubleshooter
18
Anawat
Anawat
Mentor
Posted: ‎2020-06-15 05:06 PM . Last Modified: ‎2020-09-10 12:26 AM
14
13980
I'm working on M172 controllers and need to use BACnet protocol.
Anybody know where can i download BACnet Addons Library for Ecostruxure Machine Expert HVAC?
  • Connectivity
  • HVAC
  • M172
  • modicon
  • SoMachineHVAC
Posted: ‎2020-06-16 11:18 AM
13
13972
Hi, you can download the BACnet Addons library for ESME HVAC from this link: https://schneider-electric.box.com/s/7r58enj2e5wk3i08v37jyho5apsy445j
Please feel free to reach out for any question you might have in this regards.
Pierpaolo
Pierpaolo Armeli
Technical Expert Community Facilitator & HVAC Expert
  • bacnet
Posted: ‎2020-06-24 12:30 AM
In response to Anonymous user
Hi Anawat,
As discussed, the best in this case is to use a workaround, as by using a mirror point and alarm object in EBO system.
Pier
Replies 14
13
13973
Pierpaolo
Pierpaolo Armeli
  • bacnet
Anawat
Anawat
Mentor
Posted: ‎2020-06-16 04:32 PM
@Anonymous user
Thank you very much.
Anawat
Anawat
Mentor
Posted: ‎2020-06-20 05:49 PM
13915
Hi Pier,
I am able to discover MP172 BACnet device and objects into EBO.
i have one issue about alarm and reset text Message of BI object. These are not propertied in ESME to add.
Posted: ‎2020-06-22 06:11 AM
In response to Anawat
13899
the string fields can be edited only from the PLC (they are read-only)
You can double check on the PICS which properties are implemented (https://www.bacnetinternational.net/btl/index.php?m=266) - they are in line with the AAC profile.
Please contact me directly to investigate further and then we can report here the findings.
Thank you.
Anawat
Anawat
Mentor
Posted: ‎2020-06-22 10:23 PM
I got it. Thank you.
Hi Anawat,
Pier
VaidasM
VaidasM
Contributor
Posted: ‎2021-10-28 09:38 AM
11052
we are using Bacnet Library 2.3 version within M172 controllers for AHU application and we experience random disconnections from the network. We've moved Bacnet task from background to timed task (we believe their priority is higher), also made longer timeouts on Bacnet line in AS-P, situation got a lot better, but not perfect - disconnections still occurs. Do you have any ideas ?
Thank you.
Anawat
Anawat
Mentor
Posted: ‎2021-11-02 02:23 AM . Last Modified: ‎2025-08-12 05:20 AM
In response to VaidasM
I'm not found this error before. You can try to check the below link. It might be help.
Schneider M172 PLC and AS-P BACnet communication problem.
jf_graphen_pl_b
jf_graphen_pl_b
Explorer
Posted: ‎2022-08-25 01:11 AM
9674
Hello Pierpaolo,
I 've the same kindly request but concerning  Modbus. Would you like to send  al link to MODBUS Addons Library for Ecostruxure Machine Expert HVAC?
Thanking in advance,
Artur
Ismet_S
Ismet_S Contributor
Contributor
Posted: ‎2022-08-26 01:53 PM
In response to jf_graphen_pl_b
9610
By default the Modbus Addon "ModBUS_Addons_M172P_O.plclib" is under the folder :
"C:\Program Files (x86)\Schneider Electric\EcoStruxureMachineExpertHVAC\Catalog\FreeAdvance\PLC"
BR
BenoitDery
BenoitDery Explorer
Explorer
Posted: ‎2022-10-24 05:44 AM
In response to Ismet_S
9289
I couldn't find the ModBUS_Addons_M172P_O library in the mentioned folder, neither in ESME HVAC V1.1 nor V1.4.
Is there some place else it can be found?
  • addon
  • modbus
Ismet_S
Ismet_S Contributor
Contributor
Posted: ‎2022-10-24 05:53 AM
In response to BenoitDery
9282
Please see attached.
BR
ModBUS_Addons_M172P_O_Lib_v1.5.1.zip
BenoitDery
BenoitDery Explorer
Explorer
Posted: ‎2022-10-24 05:56 AM
Many thanks!!
