HMI communication
HVAC and Pumping Forum
Send InviteCancel
Posted: 2022-10-1307:44 AM
HMI communication
I try to connect the HMI with R & B PLC through Modbus TCP IP but no connect IP address is 192.168.0.166 ID2 little endian 0 bit base when I use Modscan64 I can read data from PLC and IF I use Modsim64 I can send data to HMI same address but if I connect HMI with PLC no communication
