Creating Arrays in ESME HVAC
HVAC and Pumping Forum
Select a Country
  • Industrial Automation
  • HVAC and Pumping Forum
  • Creating Arrays in ESME HVAC
FedericoM
FedericoM Mentor
119
Bastian_Schmitz
Bastian_Schmitz Champion
64
M_Cervati
M_Cervati Troubleshooter
18
EcoStruxure™ Machine Expert - HVAC
POPE3909
POPE3909
Explorer
Posted: ‎2024-11-20 10:01 PM
1043
Hi Guys,
I'm stuck while trying to create an Array with its size (Upper bound) being a EEPROM variable instead of a set constant value.
Here, Num_Units is an EEPROM variable which is also UINT. When I compile it, I got the following error.
If I replace the Num_Units with its value (eg: 10), it complies successfully and creates an array of size 11 (0-10). I tried declaring inside the ST program like the following, but the program does not allow me to do so:
How can I achieve this please? Any advice would be greatly appreciated. Thanks.
  • HVAC
FedericoM
FedericoM Mentor
Mentor
Posted: ‎2024-11-22 05:59 AM
this is not supported, the size of an array has to be based on a constant value or a constant variable, because the space is allocated at compilation time.
You have to define the array with a size equal to the maximum value that can be assumed by your EEprom parameter and use just part of it when the EEprom value is lower than maximum.
FedericoM
FedericoM Mentor
Mentor
