Checklist to deploy EcoStruxure IT Gateway
Get started with EcoStruxure IT
Everything you need to get started with EcoStruxure IT. Create an account, install the EcoStruxure IT Gateway, and download the mobile app.
  • EcoStruxure IT Help Center
  • Resources
  • Get started with EcoStruxure IT
  • Checklist to deploy EcoStruxure IT Gateway
  • Mark as Read
  • Demo available: IT Expert and EcoStruxure IT app
  • Notifications on the EcoStruxure IT website
EcoStruxure IT Support
Request Support
Back to Get started with EcoStruxure IT
  • Mark as Read
Picard EcoStruxureIT
‎2019-04-04 07:13 AM
Last Updated: Sisko JLehr Sisko ‎2025-10-20 11:12 AM
This checklist will help you make sure you have the necessary information to deploy the EcoStruxure IT Gateway and discover devices successfully.
Installing and setting up the EcoStruxure IT Gateway - version 1.10 and newer
Server or VM
Server or VM to download and install EcoStruxure IT Gateway on.
Not applicable for the EcoStruxure IT Gateway appliance, which comes with the Gateway software preinstalled.
System requirements
Device IP addresses
You can import a device list in .CSV or .TXT format.
You can include SNMPv1, SNMPv3, NetBotz, and Redfish devices in one list. You import a list of Modbus devices separately.
List of IP addresses, IP address ranges, or subnets to discover devices on.
File transfer credentials - FTP and/or SCP
Username _________________
Password __________________
Port ____________
Device credentials
SNMPv1 enabled
Read community name (public is default) ___________________________
Write community name (private is default) __________________________
Port (161 is default) __________
SNMPv3 enabled
The small Gateway configuration can monitor up to 60 SNMPv3 devices total.
System requirements
EcoStruxure IT Gateway versions older than 1.15 do not allow discovery of SNMPv3 devices with the Authentication type or Encryption type set to None.
Note: When AES is configured on the APC NMC, choose AES128 in the Gateway.
Authentication type (MD5 or SHA) __________
Authentication password ________________
Encryption type (DES, DES3, AES128, AES192, AES256) ______________
Encryption password ________________
Port (161 is default) _____________
NetBotz
Username ____________________
Password _____________________
Port (80 is default, or 443 with SSL enabled) _____________
Web
Required to retrieve video clips from NetBotz 750/755 surveillance cameras
Port (443 is default) _____________
Redfish
Username _____________________
Password ______________________
Modbus
For each Modbus device to discover:
Device type ___________________
Device vendor _________________
Device family __________________
Server address ____________
For TCP:
IP address ____________________
Port (502 is default) _________
For serial:
Port _________
Baud rate _________
Data bits __________
Parity __________
Stop bits __________
Flow control __________
SSL certificate
If your organization operates an SSL inspection proxy and EcoStruxure IT Gateway does not trust the issuing CA, add the certificate authority's (CA) root certificate to the EcoStruxure IT Gateway trust store.
Your IT department can provide the correct root certificate.
The certificate must be in PEM format with one of the following extensions: cer, crt, or pem.
No certificate needed
Certificate file _______________________
Proxy server
The Gateway server must use the internet to communicate with EcoStruxure IT.
No proxy server needed
Proxy server
You can automatically detect the proxy server or configure settings manually.
Manual settings:
Proxy server address _________________
HTTP port __________________
HTTPS port __________________
