| User | Count |
| 116 | |
| 58 | |
| 46 | |
| 32 |
Hi Adrian,
Please find the answer
- What is the filesystem size/free space ? : Flash - 128 MB (total), used around (10 MB)
- What is the size of Ethernet Physical port 1 Reception/Transmission Buffer? : On Application side we support - 32 (tcp connection) * 32 (serial packet ) * 255 bytes of memory.
- What is the size of Ethernet Physical port 2 Reception/Transmission Buffer? : 32 (tcp connection) * 32 (serial packet ) * 255 bytes of memory.
- What is the size of EEPROM? 32Kbytes? : 64 KB
- What is the size of DDR RAM? : 256 MB
Kamal Kumar
Link150 does not offer data logging.
but the internal memory?
The Link150 does not have user accessible internal memory as it does not have datalogging function. It only gives functional status of the boot memory, EEPROM and DDR RAM. For more information, please refer to the user manual link below,
www2.schneider-electric.com/resources/sites/SCHNEIDER_ELECTRIC/content/live/FAQS/276000/FA276295/en_US/EGX150UserGuide.pdf
Best Regards,
Tan Kuan Khoon
Senior Specialist
Product Application & Engineering
Schneider Electric Singapore
To exhaust the subject, can anyone answer, ordered by higher importance:
Hi Adrian,
Kamal Kumar
You mentioned that the LINK150 supports 32 TCP connections above. But from what I have found out from the user guide, the user can only choose 8 or 16 "TCP/IP Client connections" from the web configuration interface.
Does this mean we will see this option going up to 32 in the future firmware release? It is important when try to replace EGX100, since EGX300 supports 32 connections by default and can be increased to 48 (or 64, don't recall exactly).
Yu Diao Yes , in the future release of firmware it is going to support 32 TCP/IP connection as of now it is limited to 8 or16.
Kamal Kumar
