Any assistance with getting a Com'X to publish would be appreciated. The 'invoke-webrequest' powershell commmand confirms that csv files should send to the publication server without issue.
When running the Diagnostics Network tool in Com'X 510 Network settings, an error arises when checking the publication server :
* error:14077410:SSL routines:SSL23_GET_SERVER_HELLO:sslv3 alert handshake failure
The message in full is:
>> Testing HTTPS server X.X.X.X:443
+ curl https://X.X.X.X:443 -vs -o /dev/null -k
* Rebuilt URL to: https://X.X.X.X:443/
* Trying 104.21.5.170...
* TCP_NODELAY set
* Connected to X.X.X.X (X.X.X.X) port 443 (#0)
* ALPN, offering http/1.1
* Cipher selection: ALL:!EXPORT:!EXPORT40:!EXPORT56:!aNULL:!LOW:!RC4:@STRENGTH
* successfully set certificate verify locations:
* CAfile: none
CApath: /usr/ssl/certs
* TLSv1.2 (OUT), TLS header, Certificate Status (22):
} [5 bytes data]
* TLSv1.2 (OUT), TLS handshake, Client hello (1):
} [512 bytes data]
* TLSv1.0 (IN), TLS header, Unknown (21):
{ [5 bytes data]
* TLSv1.0 (IN), TLS alert, Server hello (2):
{ [2 bytes data]
* Curl_http_done: called premature == 1
* Closing connection 0
Hi.
Please contact your Customer Care Center for assistance with this issue.
Randi
Hi.
Randi
