export csv file to SFTP Server with PAS 800
Gateways and Energy Servers
  • EcoStruxure Power & Grid
  • Gateways and Energy Servers
  • export csv file to SFTP Server with PAS 800
Romain_Polette
Kirk Romain_Polette Kirk
117
Guillaume_Evrard
59
Randi_Dolan
46
Thierry_Baudard
Commander Thierry_Baudard Commander
Commander
Posted: ‎2022-06-29 01:36 AM . Last Modified: ‎2022-06-29 01:38 AM
5457
@swil
your question was moved in this  specific post. don't hesitate to create new post for next question
1. Will SFTP publishing be enabled in PAS800 Panel Servers? (previously I thought SFTP was a feature of PAS800)
2. Can instructions on setting up HTTPS file transfer publishing from one or more PAS800 servers to a PME server be provided?
3. Can instructions on copying PAS800 server logged csv data from PME server to PME server ION database be provided? (i.e. ETL tool configuration for the PAS800 csv files to backfill to PME database where data gaps exist)
Thierry BAUDARD
EcoStruxure Power- Technical Support Expert for Softwares & Solutions
  • Product selection
Tags (2)
  • SFTP Server
Replies 15
Thierry_Baudard
Commander
Posted: ‎2022-06-29 02:09 AM
5447
Hello swil
Q1: I don't really understand the question but I assume that you wan to know if the SFTP publishing (csv export feature) will be available on other PAS model (PAS400 and PAS600)...
csv export feature will be available for the 3 models : PAS400 / PAS 600 /PAS800.
The difference will be that the P800 has a datalogger of three years and can support upper network disconnection longer than one month  to avoid gag in the PME DB. PAS400/PAS600 has a maximum buffer of approximately one month and can avoid only a shorter  disconnection.
However this feature is forecasted in tentative status (not commited status today) for the version 1.5 in October 2022
Today with the current version 1.3.2, the export is performed by the user in the Panel server web page and the export is only on his laptop
Q2:
I m pretty sure that the instruction will be available in the user guide and relative to  a generic SFTP server (no specific instruction for a PME server)
Q3:
this question is relative to PME and I don't know  if the dev team forecast to publish a tech note/TVDA  (or similar) relative to this topic.
BR
Thierry BAUDARD
swil
Commander swil
Commander
Posted: ‎2022-06-30 01:16 AM . Last Modified: ‎2022-06-30 01:28 AM
Thanks @Thierry_Baudard for the responses.
I didn't realise that the lower level PAS devices e.g. PAS600 would be equipped to log at all.. The PAS600 'data sampling' feature looks interesting. (looks like it is for PAS servers connecting to a Schneider cloud, not for PAS servers connecting to PME).
Is October 2022 the  ETA for the PAS800 to be able to publish files over SFTP? Question1 was written because the Version 3 (05/22) PAS user manual (which seems to cover all PAS servers) does not reference SFTP. It also seems very light on instructions to publish data to a server on the network (it is hoped that the PAS800 will do everything that a Com'X can do including this, custom modbus device types etc.).
Regarding Q2, and Q3, A clear description of how to use the PAS800 to replace existing Com'Xs functionality with PME would be welcomed (i.e csv file transfer to PME server setup and database backfilling using the csv files)
RicardoEstima
Crewman RicardoEstima Crewman
Crewman
Posted: ‎2023-02-14 12:17 PM
4903
@Thierry_Baudard is the csv feature export to sftp implemented on 001.005.000?
sesa64390_bridg
Lt. Commander sesa64390_bridg Lt. Commander
Lt. Commander
Posted: ‎2023-02-14 12:23 PM
SFTP publication is implemented on PAS800 with firmware 1.5.0
SFTP publication will be implemented on PAS600 with firmware 1.5.1 (to be released any day now).
HTTPs publication is expected for firmware 1.6.0 for both PAS600 and PAS800 range
RicardoEstima
Crewman
Posted: ‎2023-02-14 01:12 PM
@sesa64390_bridg do you have any pictures or manual of the sftp publication?
Regarding https you mean POST HTTP or POST HTTPs?
Thierry_Baudard
Commander
Posted: ‎2023-02-16 03:18 AM
1
4861
I am sharing a screenshot to help you with this.
I am not the author (thanks to this colleague! ‌‌, he will recognize himself) and it was made with fw1.5.0
For information, Improvement in fw1.5.1 will be a 2nd additional method of identification and the possibility of selecting a subfolder in the SFTP server (today only possible to select the root)
I hope it can help
Thierry BAUDARD
RicardoEstima
Crewman
Posted: ‎2023-02-16 04:35 AM
@Thierry_Baudard i am afraid to say that the sftp must be with problems. I am always getting authentication failed!
Thierry_Baudard
Commander
Posted: ‎2023-02-16 08:53 AM
@RicardoEstima : we directly contact you for investigation outside the SE Community.
Thierry BAUDARD
Darren_Pearce
Lieutenant | EcoXpert Master Darren_Pearce Lieutenant | EcoXpert Master
Posted: ‎2023-06-06 01:08 AM . Last Modified: ‎2023-06-06 01:08 AM
4435
Hi Thierry,
I have just updated a PAS600T to fw 1.6.0 and cannot either setup the sftp or find anyway to download the log csv file directly from the panel server?
Do you have any screen shots of a PAS600 with fw 1.6.0?
Darren
Thierry_Baudard
Commander
Posted: ‎2023-06-09 08:10 AM
4391
Hi Darren,
Export the csv file from the webpage is not possible with PAS600 . It is only possible with PAS800.
Only the SFTP publication is possible with PAS600.
I don't have specific screenshot for the new version 1.6 but it should not be really different.
If you can wait a little, a video relative to SFTP publication with fw1.6 must be added in a few weeks in the forum (currently in creation)
Other solution now is to create a ticket on the support to help if urgent (no better solution on my side)
 Best regards
Thierry BAUDARD
Guillaume_Evrard
Captain
Posted: ‎2023-06-09 08:30 AM
SFTP publication should be available on PAS600T with fw 1.6.0 as per release note.
if your PAS has been connected to the cloud, I guess you have to factory reset it and use SFTP.
Kind Regards.
Samart_Ploypradab
Ensign Samart_Ploypradab Ensign
Ensign
Posted: ‎2024-04-03 02:21 AM
Hi Thierry
Do you have guide line for PME read this CSV file in SFTP?
Thank you
luis_dias_emr_p
Lieutenant | EcoXpert Master luis_dias_emr_p Lieutenant | EcoXpert Master
Posted: ‎2025-09-09 09:27 AM
1303
Hello Thierry,
I would like to know what is SFTP server are you using to transfer the .csv files to the server. Is it free? Is there some procedure how to configure the SFTP server and configure the PAS 8000 to load .csv files in the server?
Luís Dias
Sushant_Belote
Lt. Commander | EcoXpert Master Sushant_Belote Lt. Commander | EcoXpert Master
Posted: ‎2025-09-09 10:23 PM
Hi @luis_dias_emr_p
Usually, PME server will act as a SFTP server.
You can ref below link for creating SFTP on PME server.
How to set up an sftp server on windows 10 | how to install sftp on windows 10
In case you wanted to change the SFTP folder path.
Configure SFTP within Windows Server 2022!
After creating SFTP server you can start publication from Panel server, make sure you have enabled the sampling (Data Recoding on PAS)
Once csv files are available on PME server you can use ETL tool to load that data into ION DB.
Power Monitoring Expert 2022 (ref ETL 6.0)
Some additional FAQ
ETL EGX extract task fails for PAS600 and PAS800 FW 1.6.0 csv files | Schneider Electric Egypt and N...
Thanks & Regards
Sushant Belote
Guillaume_Evrard
Captain
Posted: ‎2025-09-09 10:29 PM
hello @luis_dias_emr_p,
SFTP is a standard protocol to exchange files ( Secure File Transfer Protocol), basically you need to have a SFTP server (can be a piece of software) you will have to configure ( credentials, IP, etc) and the PAS will push the files to this Server (Client side)
As explained, PME is having one and you can use EDC to ingest data.
Kind Regards
