PowerTag serial numbers can be longer than the modbus registers allow
Gateways and Energy Servers
Showing results forΒ
Did you mean:Β
  • EcoStruxure Power & Grid
  • Gateways and Energy Servers
  • PowerTag serial numbers can be longer than the modbus registers allow
Romain_Polette
Kirk Romain_Polette Kirk
117
Guillaume_Evrard
59
Randi_Dolan
46
EcoStruxure Panel Server Advanced
Breina
Ensign Breina
Ensign
Posted: β€Ž2024-10-28 12:37 PM
5
1247
Given a PowerTag of the following serial number:
RN-####-###-4-GH-0105
And we query the modbus section for this tag's serial:
Then we get
instead of the full serial number.
Presumably this is because the maximum length of this section is 20 bytes, whilst the actual serial number contains 21 characters. Is there a workaround for this?
Dev of the Panel Server HomeAssistant integration
  • Thumbnail of EcoStruxure Panel Server Advanced
View products (1)
  • troubleshooting
Eric_HAVAS
Lt. Commander Eric_HAVAS Lt. Commander
Lt. Commander
Posted: β€Ž2024-11-06 12:50 AM
Hello @Breina
Thank you to have raised this point, R&D has been notified of this issue.
Replies 5
Eric_HAVAS
Lt. Commander
Posted: β€Ž2024-10-29 08:39 AM
Hello @Breina
Hope you're fine.
Can you please provide a similar screenshot of the below one. I was not able to find in my config a device serial number with more than 20 chars.
Thanks in advance
Breina
Ensign Breina
Ensign
Posted: β€Ž2024-10-29 09:03 AM
Hey Eric,
Here you go:
Please forgive me censoring 7 characters, this device is not mine so I don't want to leak his serial number.
Romain_Polette
Kirk
Posted: β€Ž2024-11-04 05:40 AM . Last Modified: β€Ž2024-11-04 06:05 AM
Hello @Breina ,
I confirm, I can reproduce with a recent PTag NSX (SN = 21 char).
Value returned by Modbus Tool (only 20 char as expected):
Romain POLETTE
Solution Architect - France Operations
Eric_HAVAS
Lt. Commander
Hello @Breina
Breina
Ensign Breina
Ensign
Posted: β€Ž2024-11-07 01:18 AM
Alright, thanks lads! πŸ™‚
Β
