Panel Server video - Custom Model creation - EPC-Web
Gateways and Energy Servers
  • EcoStruxure Power & Grid
  • Gateways and Energy Servers
  • Panel Server video - Custom Model creation - EPC-Web
Romain_Polette
Kirk Romain_Polette Kirk
117
Guillaume_Evrard
59
Randi_Dolan
46
Szymon_Hochół
Captain Szymon_Hochół Captain
Captain
Posted: ‎2023-06-15 07:14 AM . Last Modified: ‎2025-10-31 06:22 AM
22
12273
Hello Community!
Here is a demonstration video of Custom Model creation process for Modbus devices that are not natively supported by PAS.
To create a custom model, discover EPC-Web Plateform click here
For more information, discover EPC-Web User Guide: https://ecostruxure.se.app/commissioning/epc-w/assets/pdf/How_to_create_a_custom_device_model_in_EPC...
The video has been created with v1.6 firmware.
Best regards
  • Commissioning
Vartika
Lieutenant Vartika
Lieutenant
Posted: ‎2024-04-03 07:21 AM
This post is intended solely for informational purposes and does not seek responses or comments. It is, therefore, marked as solved.
Replies 22
Sushant_Belote
Lt. Commander | EcoXpert Master Sushant_Belote Lt. Commander | EcoXpert Master
Posted: ‎2023-06-21 05:34 AM
12208
Hi @Szymon_Hochół
Thanks for the video.
Can you please share the link for PDM to retrieve the short name label for Measurements?
Thanks & Regards
Sushant Belote
Guillaume_Evrard
Captain
Posted: ‎2023-06-21 10:14 PM . Last Modified: ‎2025-04-16 12:38 PM
12188
as far as I know PDM is an internal SE website, not sure that it is accessible externally
EPC Web is suggesting the right PDM shortname example if you type I, you will get IA, IB,IC etc... and upon selection you have the label of the measurement for IA,B,C you get current.
EPC W team is working on a new interface that will ease the use of the tool.
Sushant_Belote
Posted: ‎2023-07-07 03:10 AM
Hi @Guillaume_Evrard
Thanks for the update.
Please share the link for EPC Web.
Thanks & Regards
Sushant Belote
Thierry_Baudard
Commander Thierry_Baudard Commander
Commander
Posted: ‎2023-07-10 05:12 AM
Hello @Sushant_Belote
As mentionned by @Guillaume_Evrard   EPC-Web is not yet open to external SE people but only in beta-test phase for identified  internal user
Please contact your local Schneider electric support to findan alternative solution for the development of your custom model by a local Schneider Electric Process Application Engineer
Best regards
Thierry BAUDARD
EcoStruxure Power- Technical Support Expert for Softwares & Solutions
Song-hee
Ensign Song-hee Ensign
Ensign
Posted: ‎2023-08-29 11:07 PM . Last Modified: ‎2023-08-29 11:10 PM
11679
Hi @Szymon_Hochół
I'm looking for customized alarm notification via E-mail in PAS800, it's really good exercise video to custom model integration with Panel Server.
Do you know how to get "create" authority in EPC Web or who is the related person?
Thank you in advance.
Szymon_Hochół
Captain
Posted: ‎2023-08-31 09:27 AM
Hi @Song-hee ,
currently it is not possible to create custom alarms and have notifications about them via e-mail from PAS.
What do you mean by "authority" regarding the EPC Web?
BR
Rauno
Crewman Rauno Crewman
Crewman
Posted: ‎2023-10-04 04:51 AM
11506
Hi @Szymon_Hochół,
Would be a very useful tool for us PME engineers. Any updates on when it will become available?
Currently looking at EPC web with my user and it only has a limited amount of models available and no create function.
Cheers,
Rauno
Sushant_Belote
Posted: ‎2023-10-04 05:36 AM . Last Modified: ‎2025-04-16 12:19 PM
3
11502
Hi @Rauno
Have you tried this link?
Thanks & Regards
Sushant Belote
Rauno
Crewman
Posted: ‎2023-10-05 12:27 AM
Thanks, that works
RdM
Ensign RdM
Ensign
Posted: ‎2024-03-17 10:34 PM
10822
Hello @Szymon_Hochół ,
I am encountering an issue when creating a custom model in EPC. The model requires read of a number of registers with Format INT32-MOD10K. However, it is reading the two registers in the wrong order. When I modify the Swapping configuration to WORD_SWAP at either register level or the global level, there is no change in the data returned. Can you please advise on how I should proceed?
Guillaume_Evrard
Captain
Posted: ‎2024-03-18 09:46 PM
What is the type of your device ?
When using MOD10K (2 registers) or Quad10K (4 registers), PAS is applying "little endian" whatever the configuration of WORD SWAP, this explains why it does not change.
Little endian = Word Swap if I remember well.
It is working well for Masterpact to get Legacy Energies or settings...
Kind Regards
Vartika
Lieutenant Vartika
Lieutenant
PiotrJakubczyk
Sisko PiotrJakubczyk Sisko
Sisko
Posted: ‎2024-11-18 05:42 AM . Last Modified: ‎2024-11-19 05:26 AM
8562
The current Eco Struxure Power Commission Web URL will be discontinued from December 15th 2024. Please use the new URL and save it for future use
[edit]
corrected link as mentioned by Guillaume_Evrard
[/edit]
Guillaume_Evrard
Captain
Posted: ‎2024-11-18 09:43 PM
hello,
with QA can not be the right one : https://ecostruxure.se.app/commissioning/epc-w
Kind Regards
asparD
asparD
Cadet
Posted: ‎2024-12-12 11:48 PM
8328
Hello everyone,
I am currently trying to set up PAS600L custom model to get data from PLC through Modbus TCP/IP connection.
The model has been successfully created and exported.
I tried to import to PAS600L, yet "Invalid Model" error appeared.
I tried also some globally released model to be imported to PAS600L.
Nevertheless, the same error keep appears.
I attached the screenshot for some reference.
Anyone had same experience? Please give me some advice.
PiotrJakubczyk
Sisko
Posted: ‎2024-12-13 02:51 AM . Last Modified: ‎2024-12-13 02:51 AM
8318
@asparD  did you upgrade firmware in PAS600? What PAS version are you running?
asparD
asparD
Cadet
Posted: ‎2024-12-15 03:59 PM
8271
I upgraded the firmware to 1.9.0 version.
I attached the further detail of the PAS device I am working on.
Balamurugan
Crewman Balamurugan
Crewman
Posted: ‎2025-02-02 03:33 AM
The above weblink not valid. Please give to us valid link.
Eric_HAVAS
Lt. Commander Eric_HAVAS Lt. Commander
Lt. Commander
Posted: ‎2025-02-02 11:10 PM . Last Modified: ‎2025-02-02 11:16 PM
7645
Hello @Balamurugan
Please use url mentionned earlier by Guillaume (the 2024-11-18):
Regards
Eric
Balamurugan
Crewman Balamurugan
Crewman
Posted: ‎2025-03-04 10:59 AM
Thanks, that works
mucahit
mucahit
Cadet
Posted: ‎2025-05-21 04:57 AM
6252
Hi @asparD ,
Did you solve your problem? I have also same problem in PAS600L. When I tried to add custom model , gives invalid model error.
Guillaume_Evrard
Captain
Posted: ‎2025-05-21 10:31 PM
Hello @mucahit,
Can you provide the PAS FW ?
Can you provide the custom model ?
When was the custom model exported from EPC W ?
Please upgrade your PAS to 2.2 FW and reexport the model from EPC W and retry.
Thanking in advance,
Kind Regards
