Hello Community!
Here is a demonstration video of Custom Model creation process for Modbus devices that are not natively supported by PAS.
The video has been created with v1.6 firmware.
Best regards
Commissioning
This post is intended solely for informational purposes and does not seek responses or comments. It is, therefore, marked as solved.
Thanks for the video.
Can you please share the link for PDM to retrieve the short name label for Measurements?
Thanks & Regards
Sushant Belote
as far as I know PDM is an internal SE website, not sure that it is accessible externally
http://granier.eur.gad.schneider-electric.com/PowerDataModel/Default.aspx#
EPC Web is suggesting the right PDM shortname example if you type I, you will get IA, IB,IC etc... and upon selection you have the label of the measurement for IA,B,C you get current.
EPC W team is working on a new interface that will ease the use of the tool.
Thanks for the update.
Please share the link for EPC Web.
Thanks & Regards
Sushant Belote
Hello @Sushant_Belote
As mentionned by @Guillaume_Evrard EPC-Web is not yet open to external SE people but only in beta-test phase for identified internal user
Please contact your local Schneider electric support to findan alternative solution for the development of your custom model by a local Schneider Electric Process Application Engineer
Best regards
EcoStruxure Power- Technical Support Expert for Softwares & Solutions
I'm looking for customized alarm notification via E-mail in PAS800, it's really good exercise video to custom model integration with Panel Server.
Do you know how to get "create" authority in EPC Web or who is the related person?
Thank you in advance.
Hi @Song-hee ,
currently it is not possible to create custom alarms and have notifications about them via e-mail from PAS.
What do you mean by "authority" regarding the EPC Web?
BR
Hi @Szymon_Hochół,
Would be a very useful tool for us PME engineers. Any updates on when it will become available?
Currently looking at EPC web with my user and it only has a limited amount of models available and no create function.
Cheers,
Rauno
Hi @Rauno
Have you tried this link?
https://portal.qa.cloud-commissioning.se.com/portal/settings/user-list
Thanks & Regards
Sushant Belote
Thanks, that works
Hello @Szymon_Hochół ,
I am encountering an issue when creating a custom model in EPC. The model requires read of a number of registers with Format INT32-MOD10K. However, it is reading the two registers in the wrong order. When I modify the Swapping configuration to WORD_SWAP at either register level or the global level, there is no change in the data returned. Can you please advise on how I should proceed?
What is the type of your device ?
When using MOD10K (2 registers) or Quad10K (4 registers), PAS is applying "little endian" whatever the configuration of WORD SWAP, this explains why it does not change.
Little endian = Word Swap if I remember well.
It is working well for Masterpact to get Legacy Energies or settings...
Kind Regards
The current Eco Struxure Power Commission Web URL will be discontinued from December 15th 2024. Please use the new URL and save it for future use
https://ecostruxure.se.app/commissioning/epc-w
[edit]
corrected link as mentioned by Guillaume_Evrard
[/edit]
hello,
with QA can not be the right one : https://ecostruxure.se.app/commissioning/epc-w
Kind Regards
Hello everyone,
I am currently trying to set up PAS600L custom model to get data from PLC through Modbus TCP/IP connection.
The model has been successfully created and exported.
I tried to import to PAS600L, yet "Invalid Model" error appeared.
I tried also some globally released model to be imported to PAS600L.
Nevertheless, the same error keep appears.
I attached the screenshot for some reference.
Anyone had same experience? Please give me some advice.
I upgraded the firmware to 1.9.0 version.
I attached the further detail of the PAS device I am working on.
The above weblink not valid. Please give to us valid link.
Hello @Balamurugan
Please use url mentionned earlier by Guillaume (the 2024-11-18):
Eric
Thanks, that works
