EcoStruxure Panel Server Project creation problem
  • Power Distribution IEC
  • EcoStruxure Panel Server Project creation problem
Genghiz
Captain Genghiz Captain
93
Gregoire_Brun
80
J_Travostino
Sisko J_Travostino Sisko
70
BrianW
Lieutenant | EcoXpert Master BrianW Lieutenant | EcoXpert Master
Posted: ‎2023-07-25 05:21 AM
1724
I have an issue trying to create projects within EcoSturxure Power Commission using the PAS600L Panel Server units.
I can add devices connected to a Panel Server such as power meters to a project from which I generate reports, just I I have done with other gateway devices, such as the EGX150s which is fine, but for some reason, when I connect to IFMs and subsequently to NSX breakers with BSCM modules, although the devices show up as Modbus connected devices, when I try to add these to a project, I get a splash screen stating "Unable to add devices" as per the attached image. I note that there is no Device Type noted on the device listing either.
Is there anyone that can shed light as to how to add these IFMs/MCCBs to a project as shown?
Thanks in anticipation,
Brian
  • EcoStruxure Power Commission (EPC)
  • Software
Romain_Polette
Kirk Romain_Polette Kirk
Kirk
Posted: ‎2023-07-25 06:36 AM . Last Modified: ‎2023-07-25 06:45 AM
1719
Hello @BrianW ,
What is your EPC version and Panel Server FW ?
With EPC 2.28 + PAS800 v001.006.000 this is working.
NSX connected to IFE + IFM are discovered by EPC:
And added to the PAS800:
Devices are then available on the PAS800 Web Pages:
Romain POLETTE
Solution Architect - France Operations
Romain_Polette
Kirk
1720
Hello @BrianW ,
Romain POLETTE
BrianW
Posted: ‎2023-07-25 08:39 AM
In response to Romain_Polette
Hi Romain,
I am not sure if there is a huge difference between the PAS800 and the PAS600L that I am using here, but either way, a quick upgrade to the latest version of EPC and upgrading the PAS600L to the newest firmware certain worked and I am now able to both view and use the serial devices in a project.
Many thanks for your speedy response and correct information!
Best regards,
Brian
