Hi Dev Team of the PanelServer,
Some remarks I received and expierinced during setup of PAS800, here specific on the publication of CSV...
When starting a SFTP publication, the file that is send doesn't start from the beginning of a day till end of day. So I receive CSV files starting from 10:10:00 to the next day 10:10:00. Is there a way to change this so i have data from 1 entire day 00:00:00 -> 00:00:00. What if publication is set to 1month? will data from the entire month be send?
In the "old Com'X510" we had the possibility to select wich data is Published in the CSV, I miss this in Panelserver.
Also when you want to change log interval it needs to be done parameter by parameter for each device individually. Imagine if you have 50 meters that you need to change the logging interval from 10 to 15 minutes....
Why no publication via SMTP? feature existed in Com'X510 and I have already 1 project where PAS800 was removed because no SMTP support...
Then the Alarm publication via Cloud, if you activate this no possibility to activate SFTP and vise versa...
If SMTP is not implemented, at least leave the possibility to publish via cloud to email like the alarms....
Even if it is not a good solution for some customers as they do not allow to connect to some external servers... With SMTP they could use there own server without giving the device acces to the internet...
Why no possibility to enter a Time zone.... Not all of us live in UTC time zone....
Hope this information helps you to make the PAS more user friendly...
Kind regards
Koen
Hello Timezone is in the roadmap....
