One EGX 300 let me upload the bin file via ftp fine but will not let me send the disk image.
Tried two Windows Explorer, DOS and FileZilla to ftp. ZIP.
Now have a half updated EGX 300.
bin at newest disk image 3.380 and stuck
Can anyone help???
We cleared the logs via the web page interface and turned off logging. Also used Modbus register right to do a factory reset. Still cannot ftp image to EGX. It is acting like its "disk" is full.
Michael
Hi Michael,
I'm sorry to hear that you're having problems upgrading your EGX300.
There's a few things that may cause this issue:
Are there data log files on-board the EGX300? If so, would you save them to a PC (Data Export) and then turn off logging and purge the log files? Also, if you have any custom pages on the EGX, would you also save those files to a PC and then delete them from the EGX?
If you deleted some files, would you please try to update the disk image again. If not, please let me know and I will try to assist you with this issue.
Randii
Also, just to make sure, you are have firmware version 4.460 on the EGX and are trying to download 4.461 disk image?
EGX300 v4.461 Firmware and 4.460 Disk Update - Documents & Downloads
I'm still investigating your issue, I just wanted to make sure that you do, indeed, have the latest firmware.
Whoops... the other way around 4.461 Firmware and 4.460 Disk Image.
Hi Michael,
Would you please navigate to the <ipaddress>/disk.html webpage and select (one at a time) the following, select "Apply", and paste the results in here? (you will have to use your browser "back" button to return to the page to perform each report
Print Disk Physical Information
Print Disk Volume Information
Print Disk SuperBlock
Print Disk Directory (leave at root)
Thank you,
Randi
