Issue with gateway option
Gateways and Energy Servers
  • EcoStruxure Power & Grid
  • Gateways and Energy Servers
  • Issue with gateway option
Romain_Polette
Kirk Romain_Polette Kirk
117
Guillaume_Evrard
59
Randi_Dolan
46
sesa103388_brid
Ensign sesa103388_brid Ensign
Ensign
Posted: ‎2014-09-18 09:14 AM
3112
Hi everybody,
A part of my network is simple:
I want to read the value in SIM10 registers via my none schneider gateway
I create a gateway device in my Comx200 and I attached SIM10M to it
Unfortunately it is not working!!
I have 1.1.20 firmware
I tried with an iRIO (in case of) and it works
What can I do?
4690
Regards
Tags (3)
  • comx200
  • gateway
  • issue
Replies 5
sgamot
sgamot Schneider Alumni (Retired)
Posted: ‎2014-09-18 02:31 PM
3019
What is the network configuration of the Com'X and how is connected the Modbus master that needs to read the SIM10 registers ?
The section 7.5 Gateway access of the user guide shows the possible architectures.
If the Com'X is in 2 separate ports mode, the Modbus master on the WAN side, the Modbus slaves on the LAN side, then it will not work.
Sylvain
sesa103388_brid
Ensign
Posted: ‎2014-09-18 11:48 PM
3019
We choose the separate port option for network configuration and use port 1 to send datas to EO and port 2 for modbus
page 63, I use separated ports, first architecture
4711
So I think, this part is correct
Regards
sgamot
Posted: ‎2014-09-19 12:24 AM
3019
How the modbus gateway gets its IP address? Is it static or allocated through DHCP?
Does it work if you add a laptop on eth2 and try to access to the SIM through the gateway thanks to a Modbus client?
Sylvain
sesa103388_brid
Ensign
Posted: ‎2014-09-19 12:45 AM
3019
It is a static ip for both eth ports.
I did not try to access to the SIM though the gateway with a modbus client
but I replace the comX200 with an iRIO and it works.
Regards
sgamot
Posted: ‎2014-09-19 01:02 AM
If you push me the configuration backup of your Com'X I could have a look on it.
If you do so please send it to my Schneider email for privacy purpose.
Sylvain
