Posted: 2022-05-12 07:45 AM . Last Modified: 2022-05-12 07:50 AM
Hello Expert team,
Can I connect FDM128 to a Panel server 600 to display the data on the front face of my panel?
Best regards
Charlie
Hello @Anonymous user ,
It is possible by using the latest firmware version on FDM128 and PAS600 with a limitation of wireless devices displayed (PowerTag, HeatTag,TH110, and CL110).
Hello @Anonymous user and @Olivier_GARAULT ,
Quick update on the topic.
It seems that FDM128 v8.0.28 is not yet compatible with the PAS600 001.003.001.
We need to wait the next FDM128 release (8.0.29 or later).
Bonjour,
Merci pour le renseignement.
Pour information, on vient d'apprendre que le Panel Server n'est pas encore qualifié pour les enveloppes Okken.
La consigne est de continuer à utiliser le PTL.
On fera quand même des tests avec la prochaine version du FDM128.
I am really surprised by the previous answer that PAS is not validated inside Okken, can someone provide what is the real status ?
There is confusion in the previous message published by Olivier Garault.
Olivier refers to the validation of Panel Server into the SMD solution which is a thermal monitoring solution based on TH110 and whose validation is currently in progress (and not validation in the OKKEN enclosure).
So, obviously, Panel Server fulfills all the conditions, validation and certification to be installed in the OKKEN standard. There is no problem !
What is the actual status of this point?
I go to a panel builder tomorrow and this is one of the topics we need to solve.
BR Geeke
Hi @sesa242973_brid ,
It seems that the latest version of the FDM128 application is now available:
https://www.se.com/fr/fr/download/document/EnerlinX_FDM128_software/
I have not yet tested it but normally FDM128 v8.0.30 should work with Panel Server.
Gd day,
After updating the Firmware V8.0.30 on FDM 128. Still unable to configure/communicate with PAS600 / PAS800 Panel Servers.
I'm configuring it through Smart link communication settings under device discovery in FDM128. Will be waiting for a prompt solution.
Thanks and regards,
Shariq
Hello @Chilcott ,
What is not working ?
All good everything is working now.
After Updating firmware on both PAS600 (Pannel Server) and FDM128 (LCD Screen) Everything is working now. Thank you.
Hello @Chilcott ,
FYI a new version 8.0.37 of the FDM128 was released last week.
Did you install this version ?
