How to connect third-party Modbus devices to panel server
Gateways and Energy Servers
  • EcoStruxure Power & Grid
  • Gateways and Energy Servers
  • How to connect third-party Modbus devices to panel server
Romain_Polette
Kirk Romain_Polette Kirk
117
Guillaume_Evrard
59
Randi_Dolan
46
EcoStruxure Panel Server Universal
Stuart_Cheng
Lt. Commander Stuart_Cheng Lt. Commander
Lt. Commander
Posted: ‎2022-11-21 08:03 AM
5210
Hi All,
From the official presentation, we know that a panel server can also be used to collect data from third-party devices. However, I could not find any detailed procedure on how to connect and map the registers. Does anyone have relevant information? Thank you
  • Thumbnail of EcoStruxure Panel Server Universal
View products (1)
  • Commissioning
Guillaume_Evrard
Captain
Posted: ‎2022-11-21 08:12 AM
5203
There is a cloud based tool called Commisioning Web portal to create "models" to be loaded on the PAS using the Web Pages.
As of today only few SE Employees are having access to the tool.
Pay attention that some limitations exist with FW 1.4 and 1.5 regarding modbus communication ( Only FC03 read holding register, same endianess for all the measurements, ....)
Replies 9
Guillaume_Evrard
Captain
5204
Eric_HAVAS
Lt. Commander Eric_HAVAS Lt. Commander
Lt. Commander
Posted: ‎2022-11-22 12:16 AM
5168
Hello Stuart,
I remind that  you are one of this only few SE Employees who have already access to this web portal (CWP) to create custom models for their countries.
Regards
Eric
Thierry_Baudard
Commander Thierry_Baudard Commander
Commander
Posted: ‎2022-11-25 01:37 AM
3
5091
I also to add one comment about Custom model in Panel Server.
If the need is just to collect Modbus registers from downstream products in a Modbus TCP/IP client through the Panel Server (example PME used with modbus drivers for connected products), Custom models are not needed.In this case, The Panel Server just acts as a Transparent gateway (such as Link150) and will forward the Traffic (even if the product are not discovered in the Panel Server)
Custom model for Downstream product will be mandatory only if the Panel Server is used as A Local energy Server or for Schneider Electric Cloud connection,
For my two cents !
Thierry BAUDARD
EcoStruxure Power- Technical Support Expert for Softwares & Solutions
Guillaume_Evrard
Captain
Posted: ‎2022-11-25 01:56 AM
5086
and do not configure the devices in PAS to not replace the modbus ID by the virtual ID....
PerFrederiksen
PerFrederiksen Cadet
Cadet
Posted: ‎2023-02-14 01:54 PM
4687
"and do not configure the devices in PAS to not replace the modbus ID by the virtual ID...."
So virtual ID should not be enabled if the panel server is used to just read  holding registers from various devices ?
BR Per
Guillaume_Evrard
Captain
Posted: ‎2023-02-14 10:03 PM
PAS and COMX are working in the same way regarding modbus gateway.
If there is a virtual ID matching the ID requested by the poller it will be "forwarde" to the device. If there is no Virtual ID matching, the frames should be pushed to the serial interface for the device with ID = ID requested.
Thierry_Baudard
Commander
Posted: ‎2023-02-14 11:13 PM
A video previously posted to illustrate what are a Modbus ID and a Modbus Virtual Server ID
Panel Server Video è Server ID and virtual Server ID
Thierry BAUDARD
Christopher.odonnell
Lieutenant | EcoXpert Master Christopher.odonnell Lieutenant | EcoXpert Master
Posted: ‎2024-05-27 01:26 AM
3007
Trying to add an Exertherm data card to a PAS600L but cannot manually add any help on how to do so would be great.
Guillaume_Evrard
Captain
Posted: ‎2024-05-27 08:50 PM
Hello @Christopher.odonnell,
Are you facing issue to create the model with EPC W or adding the device in PAS ?
I guess that you want to collect data from the thermal monitoring and not use the PAS as a modbus tcp gateway ?
Kind Regards
