Do we have any software to install on a PC to emulate a serial modbus port ?
Gateways and Energy Servers
  • EcoStruxure Power & Grid
  • Gateways and Energy Servers
  • Do we have any software to install on a PC to emulate a serial modbus port ?
Romain_Polette
Kirk Romain_Polette Kirk
117
Guillaume_Evrard
58
Randi_Dolan
46
Guillaume_Evrard
Captain
Posted: ‎2022-02-10 04:37 AM
2452
I have a device connected to a link150 using RS485. I would like to emulate a Com port on my laptop to connect to the device.
The tool needs to allow me to enter IP address and slave device ID.
Do you have a handy tool ?
Thanking in advance,
Replies 9
Randi_Dolan
Commander
Posted: ‎2022-02-10 05:09 AM
2450
We like to use Modsim 32 - https://www.win-tech.com/html/modsim32.htm
Guillaume_Evrard
Captain
Posted: ‎2022-02-10 07:27 AM
2446
Thanks a lot Randi, but is it possible to use modsim to act as a virtual com port ?
I would like to use easergypro on my laptop to connect to serial port of protection relay through a link150.
Easergy pro does not allow to enter the slave ID of the relay....
Szymon_Hochół
Captain Szymon_Hochół Captain
Captain
Posted: ‎2022-02-15 01:48 AM
Hi @Guillaume_Evrard
I'm not aware of any software solution to be used with Link150, but I think that MOXA's NPort device could be what you are looking for.
Olivier_GARAULT
Lieutenant JG Olivier_GARAULT Lieutenant JG
Lieutenant JG
Posted: ‎2022-02-15 04:11 AM
2439
Bonjour,
cela fait des années que l'on utilise Modscan32 et on n'a encore rien trouvé de mieux ni d'aussi simple et rapide.
Guillaume_Evrard
Captain
Posted: ‎2022-02-15 05:07 AM
2437
Bonjour,
Comment fais-tu pour pouvoir avoir modscan32 = Com port Virtuel ?
Mon but est d'aller chercher un équipement connecté en série avec un logiciel qui ne permet pas d'entrer une adresse IP et un esclave modbus....
Olivier_GARAULT
Lieutenant JG
Posted: ‎2022-02-15 05:34 AM . Last Modified: ‎2022-02-15 05:42 AM
2435
Il faut configurer les IP sur la Link150 et dans modscan.
Configurer également la partie Modbus, par défaut on met 19200 8 bits 1 stop Even 0,5sec
sur la photo c'est un exemple pour lire une valeur sur un IM400.
Au passage cela nous arrive de faire une formation à Rennes sur quelques basiques de la communication des équipements, pour des Schneider et des clients, cela dure une journée; (en support on utilise des TGBT Okken)
Romain_Polette
Kirk
Posted: ‎2022-02-15 06:10 AM . Last Modified: ‎2022-10-19 01:06 AM
2427
Hello @sesa157458_brid ,
For use with eSetup Easergy Pro => I do not think this is possible.
Documentation is not mentioning this option:
https://download.schneider-electric.com/files?p_enDocType=User+guide&p_File_Name=eSetupEasergyPro_EN...
Not sure you can commission P3 or P5 through Link150. You can do some setup but only with the Web Pages of the device.
For P3 + eSetup EasergyPro => only through front face (COM port of your Laptop) or direct Ethernet.
Better ask here:
https://community.se.com/t5/PAE-Protection-Relays-Controllers/bd-p/energy-automation
Romain POLETTE
Solution Architect - France Operations
Guillaume_Evrard
Captain
Posted: ‎2022-02-15 07:04 AM
Merci mais ce n'est pas mon besoin, et je connais modpoll, modscan....
Guillaume_Evrard
Captain
Posted: ‎2022-02-15 07:06 AM
In this case this a P1 and you can have Modbus S1 that seems modbus.
