HI admin,
I have wonder.
My customer use Zigbee connect RS485 to LINK150. From LINK150 will connect with software of Siemens.
My scope is connect sensor to Zigbee and use my laptop read data from Zigbee via LINK150.
But i don't know software can read data Sensor from Zigbee via LINK150. Can you help me. Thanks very much
Hello @SESA_B ,
Is your goal to read CL110/TH110 data from the ZBRN32 ?
Did you check following topic ?
Do you need the internal modbus map of the ZBRN32 ?
You can read Modbus Registers directly from the Link150 Web Interface for some testing.
Hello @SESA_B ,
Hi @Romain_Polette ,
Thanks for your information. I have reply:
Do you need the internal modbus map of the ZBRN32 ? => YES. I NEED INTERNAL MODBUS OF ZIGBEE
You can read Modbus Registers directly from the Link150 Web Interface for some testing. (See my pic attached) but i don't know mean values (yellow)
