Com`X510
Gateways and Energy Servers
  • EcoStruxure Power & Grid
  • Gateways and Energy Servers
  • Com`X510
Romain_Polette
Kirk Romain_Polette Kirk
116
Guillaume_Evrard
58
Randi_Dolan
46
AndersDahlskog
Lieutenant AndersDahlskog Lieutenant
Lieutenant
Posted: ‎2021-10-14 04:27 AM . Last Modified: ‎2022-05-05 07:58 AM
921
Com`X510
Hi will the new Panel Server be added in device type list when adding a custom Ethernet device in future firmware of Com´X510 ?
Thinking of all existing installations.
BR/Anders
  • Legacy Gateways & Energy Servers
  • Product selection
Randi_Dolan
Commander
Posted: ‎2021-10-14 04:43 AM
Hi Anders,
No, there will not be any future releases of the Com'X510 firmware.
However, you can select a "Generic Modbus TCP to Serial Gateway" in the Com'X and it will work with the Panel Server (or any other Modbus TCP to Serial Gateway).
Randi
Randi_Dolan
Commander
Hi Anders,
Randi
Romain_Polette
Kirk
Posted: ‎2021-10-14 07:11 AM . Last Modified: ‎2021-10-14 07:12 AM
Hello @AndersDahlskog ,
Answer is no. There is no future Com'X FW planned. v6.8.4 will be the last one.
The Panel Server will progressively replace the Com'X. There is no plan to integrate the PASxxx as Ethernet Device of the Com'X.
Workaround:
  1. If you want to connect Panel Server Modbus Devices => you need to select "Generic Modbus TCP to Serial Gateway".
  2. If you want to connect PowerTag paired with a Panel Server.... you can "cheat" by using a "Powertag Link Gateway" because the Modbus Mapping and Power Data Model is the same for the moment. PowerTag Device type will be automatically recognized by the Com'X. This is not the case with a "Generic Modbus TCP to Serial Gateway"
The next PAS800 will have the Energy Server feature.
Romain POLETTE
Solution Architect - France Operations
