ComX not getting passed boot up screen
Gateways and Energy Servers
  • EcoStruxure Power & Grid
  • Gateways and Energy Servers
  • ComX not getting passed boot up screen
Romain_Polette
Kirk Romain_Polette Kirk
116
Guillaume_Evrard
58
Randi_Dolan
46
james-wood-tel
Crewman james-wood-tel Crewman
Crewman
Posted: ‎2020-02-07 06:54 AM
12
2097
Does anyone have any fixes to get our ComX510 passed the boot up screen. We've done a power cycle and still no response.
Any support greatly appreciated
Randi_Dolan
Commander
Posted: ‎2020-02-26 08:29 AM
This is an issue with Com'X firmware version 6.5.4.  However, this was resolved with Com'X firmware version 6.5.5, attached below.
We apologize for the inconvenience.
Randi
Com'X 210 v6.5.5.zip
Com'X 510 v6.5.5.zip
Replies 12
Randi_Dolan
Commander
Posted: ‎2020-02-07 07:21 AM
2094
What version firmware is the Com'X 510 using?
Randi
james-wood-tel
Crewman
Posted: ‎2020-02-10 12:52 AM
2091
Hi Randi, we're on 6.5.4.
Randi_Dolan
Commander
Posted: ‎2020-02-10 04:07 AM
2087
Hi James,
Would you try changing the firmware version to 6.0.7 using the USB method?
Randi
james-wood-tel
Crewman
Posted: ‎2020-02-10 05:26 AM
2081
Hi, downgraded to 6.0.7 and still on boot up screen. Any other ideas
Randi_Dolan
Commander
Posted: ‎2020-02-10 06:13 AM
2079
I don't have any other ideas other than to wait a bit.  Sometimes the Com'X takes a while to boot if there are a lot of devices configured.  Do you recall how many devices were configured on the Com'X?
Randi
Jun_Escano
Lieutenant JG Jun_Escano Lieutenant JG
Lieutenant JG
Posted: ‎2020-02-11 01:26 AM
2074
We are facing the same problem and tried to pass the boot screen for already few days. We have done a complete factory reset and then it was working. However when we uploaded the backup file we got the same problem..
I am going to test it with a 'new' COMX and see whether the backup file is giving the issue.
Firmware 6.5.4
james-wood-tel
Crewman
Posted: ‎2020-02-13 01:13 AM
1
2069
OK, we are now back and running and hopefully this could assist someone in a similar situation.
Also Note we did not have the back up configuration file either. Please don't ask why đŸ˜‰
Reverted the unit to 6.0.7. This allowed us to lift the Configuration file using the USB method.
USB Extraction Method
Installed file on another ComX to validate. On opening the ComX Device Web pages found the file was corrupted.  Had to reassign gateways that were not linked to the Meters. Pretty straightforward.
Factory reset the original unit and then reinstalled the repaired configuration file. Took an age to reboot, about 1 hour but eventually got it working.
We're now back on FE.
Hope that helps someone in a similar situation. đŸ‘
Posted: ‎2020-02-18 01:33 AM
Hi @james-wood-tel,
Did you find your answer to the replies above?
If yes, please click on "Accept as Solution" at the bottom right corner of the answer which helps you.
But if you still in the same situation please do not hesitate to inform us here.
François_H
Lieutenant François_H Lieutenant
Lieutenant
Posted: ‎2020-02-26 08:00 AM
2054
@Jun_Escano
Hello
Did you solved the issue ? I got the same issue firmware 6.5.4
Best regards
François
Randi_Dolan
Commander
Randi
Jun_Escano
Lieutenant JG
Posted: ‎2020-02-26 08:54 AM
2046
After many resets and boots and backup logs it is working....but only once we've downgraded it to v6.0.7 which seems to be working as done by others before.
Randi_Dolan
Commander
Posted: ‎2020-02-26 08:55 AM
The issue was introduced in 6.5.4.  Please upgrade to 6.5.5.
Terms & Conditions Privacy Notice Change your Cookie Settings Š 2025 Schneider Electric
