Com'X200 (EBX200) Firmware
Gateways and Energy Servers
Showing results forΒ
Did you mean:Β
  • EcoStruxure Power & Grid
  • Gateways and Energy Servers
  • Com'X200 (EBX200) Firmware
Romain_Polette
Kirk Romain_Polette Kirk
117
Guillaume_Evrard
59
Randi_Dolan
46
solutions_iems-
Lt. Commander solutions_iems-
Lt. Commander
Posted: β€Ž2020-01-31 02:16 AM
2138
What is the latest firmware release for the Com'X200 and can it be upgraded with Com'X210 firmware?
Randi_Dolan
Commander
Posted: β€Ž2020-01-31 07:31 AM
2133
The latest firmware for the Com'X 200 is 3.5.54.  And, no, the firmware for the Com'X 210 will not work on the Com'X 200.
Randi
Replies 13
Randi_Dolan
Commander
2134
Randi
solutions_iems-
Lt. Commander
Posted: β€Ž2020-01-31 07:34 AM
Thanks Randi
Pavel_Melnik
Lieutenant Pavel_Melnik Lieutenant
Lieutenant
Posted: β€Ž2020-04-13 12:47 AM
2120
Hi Randi,
yet where is the source to download latest firmwares for Com'X 200 & Com'X 510?
I mean not knowing which version is the latest?
Randi_Dolan
Commander
Posted: β€Ž2020-04-13 06:00 AM
2118
To find the latest firmware for the Com'X, go to www.se.com and type the product name in the search bar.  From there, you can select the product and then select the firmware.
Pavel_Melnik
Lieutenant
Posted: β€Ž2020-04-13 06:08 AM
2116
Hi Randi,
I was able to find product page here: https://www.se.com/ww/en/product/EBX200/comx-200---data-logger/
But there is no link to download any firmware. Maybe I'm missing something?
Randi_Dolan
Commander
Posted: β€Ž2020-04-13 06:16 AM
2114
I'm not sure how you got there.  But, I typed "Com'X 200" in the search bar.  That brought up a drop down list where I selected "See more results".  Then I selected "Documents and Software" in the "Show results for" box on the left.  Then in the "filter by" ... "By Document Type" I selected "Firmware - Released", which brought up this page.https://www.se.com/us/en/search/Com'x%20200?filters=CAT_PRD_DOC&ddcDocType=1555893 ... the latest firmware is at the top of the list.
I hope this helps.
Randi
Pavel_Melnik
Lieutenant
Posted: β€Ž2020-04-13 07:57 AM
Thanks, I was able to locate the latest firmware, not exactly the way you described, but I found it. πŸ‘
Bojan
Admiral Bojan Admiral
Admiral
Posted: β€Ž2020-04-13 10:28 AM
2110
I downloaded the latest ComX510 Firmware v 6.5.5.from www.se.com and received the following error - please advise:
Randi_Dolan
Commander
Posted: β€Ž2020-04-13 10:57 AM
2108
Just curious... would you click on the "About" link on the top right hand corner and see what the version number is?
Bojan
Admiral
Posted: β€Ž2020-04-13 11:06 AM
2106
Randi_Dolan
Commander
Posted: β€Ž2020-04-13 11:17 AM
2103
Would you turn off SNTP and then try the firmware upgrade again?
Randi
Bojan
Admiral
Posted: β€Ž2020-04-13 12:55 PM
2101
With SNTP turned off it upgrade to 6.5.5 version
Randi_Dolan
Commander
Posted: β€Ž2020-04-13 12:58 PM
Thanks for this information.  We will try to address that issue.
Β
