Continue
  • My Subscriptions
  • Events
COM'x 200 Publishing all device readings in one CSV file
Gateways and Energy Servers
Schneider Electric support forum to share knowledge about product selection, installation and troubleshooting for EcoStruxure Panel Server, PowerTag, Com'X, Link150โ€ฆ
  • Exact phrase โ†’ Use quotes " " (e.g., "error 404")
  • Wildcard โ†’ Use * for partial words (e.g., build*, *tion)
  • AND / OR โ†’ Combine keywords (e.g., login AND error, login OR signโ€‘in)
  • Keep it short โ†’ Use 2โ€“3 relevant words , not full sentences
  • Filters โ†’ Narrow results by section (Knowledge Base, Users, Products)
Showing results forย
Did you mean:ย
  • EcoStruxure Power & Grid
  • Gateways and Energy Servers
  • Re: COM'x 200 Publishing all device readings in one CSV file
Romain_Polette
Romain_Polette Champion
128
Guillaume_Evrard
Guillaume_Evrard Leader
60
Eric_HAVAS
Eric_HAVAS Leader
49
Back to Gateways and Energy Servers
sean-harkin
sean-harkin
Explorer
Posted: โ€Ž2020-01-27 08:07 AM
2391
Hi
I am wondering if there is a way through the Publishing in the Com'x 200 to instead of creating one .CSV file per device to publish to an FTP server, you could create one .CSV file with all the required data from the meters. The project that the devices will be used on will contain a large number of meters so creating reports for all them would prove to be unwieldy for this.
Any help on if this is possible or not would be appreciated.
Sean
Tags (3)
  • com'x
  • com'x 200
  • com'x200
Randi_Dolan
Randi_Dolan Leader
Leader
Posted: โ€Ž2020-01-27 09:57 AM
2387
Hi Sean,
Unfortunately, the Com'X 200 does not have a method to publish all of the device readings in one CSV file.  Also, the Com'X200 is no longer in development.  So, no changes are being made to this device.
Randi
Replies 8
Randi_Dolan
Randi_Dolan Leader
Leader
2387
Hi Sean,
Randi
sean-harkin
sean-harkin
Explorer
Posted: โ€Ž2020-01-28 12:12 AM
Thanks for the update, Randi
Sean
sean-harkin
sean-harkin
Explorer
Posted: โ€Ž2020-01-28 02:37 AM
2382
Just as a follow up to this, would this be possible to achieve on a Com'x 210?
Randi_Dolan
Randi_Dolan Leader
Leader
Posted: โ€Ž2020-01-28 06:01 AM
2378
I can put it in as a feature request. ๐Ÿ™‚
sean-harkin
sean-harkin
Explorer
Posted: โ€Ž2020-01-28 07:07 AM
2375
Thanks for that. How long does it usually take to get feedback on the request
Randi_Dolan
Randi_Dolan Leader
Leader
Posted: โ€Ž2020-01-28 07:13 AM
2373
I brought it up in our meeting this morning and it seems highly unlikely that this feature will be implemented, since this device is nearing the end of it's development.  However, I've logged it for the offer manager to consider.  One "objection" that was raised stemmed around the potential size of this file and that email servers limit the size of attachments.  Regardless, it will, at least, be considered at our next increment planning, which is in late March.
sean-harkin
sean-harkin
Explorer
Posted: โ€Ž2020-01-29 01:52 AM
2368
Hi
You mentioned that the device is nearing the end of it's development for the Com'x 210. Just for clarification would that mean that the support for the device will be ending or if the device itself is being discontinued and what would be the time frame then for the end of it's development
Sean
Randi_Dolan
Randi_Dolan Leader
Leader
Posted: โ€Ž2020-01-29 06:14 AM
Support for the Com'X 200/210/510 will continue for several years.  However, development on this device is slated to end at the end of 2020.
ย
Youโ€™ve reached the end of your document
WHATโ€™S NEXT?
Terms & Conditions Privacy Notice Change your Cookie Settings ยฉ 2026 Schneider Electric
