Acti9 SmartLink - Question relation to Pulse
Gateways and Energy Servers
  • EcoStruxure Power & Grid
  • Gateways and Energy Servers
  • Acti9 SmartLink - Question relation to Pulse
Romain_Polette
Kirk Romain_Polette Kirk
117
Guillaume_Evrard
59
Randi_Dolan
46
EcoStruxure™ Power Monitoring Expert
welly_xu_quasar
Lieutenant | EcoXpert Master welly_xu_quasar Lieutenant | EcoXpert Master
Posted: ‎2022-05-09 06:33 PM . Last Modified: ‎2022-06-07 03:04 AM
1969
Hi there,
Our customer gets a PR7 pulse water meter and we want to connect to Acti 9 SmartLink.  Based on the user manual, the Ideal wiring  :   pulse cable should be connected to I1 or I2 and supplied with 24V, GND cable should be connected to 0V. This means a pulse will be generated when the voltage level from I1 or I2 drops from 24 V to 0V. This is a kind of "negative pulse " waveform.
Is there any expert who can shares their knowledge or experience if the SmartLink bar is accept this type of pulse?  Thanks in advance.
Cheers,
Welly
  • Thumbnail of EcoStruxure™ Power Monitoring Expert
View products (1)
  • Commissioning
Tags (2)
  • Acti9 SmartLink
Romain_Polette
Kirk
Posted: ‎2022-05-19 01:01 AM
1802
Hi @welly_xu_quasar ,
Smartlink only accept pulse meters compliant with IEC 62053-31 (generally called the "S0-Pulse").
  • S0+ of the meter must be connected to 24DC of an IO Channel
  • S0- connected to I1 or I2 of an IO Channel
Saia Burgess made a good summary of the definition of the S0-Output.
https://sbc-support.com/uploads/tx_srcproducts/Applicationnote_S0puls_output_EN_V1.1_01.pdf
A pulse will be counted if:
  • the current on I1/I2 is 10 / 20 mA (ON state).
  • ON state pulse is at least 30 ms
According to the Honeywell documentation, it seems that the Yellow output is not compatible with Smartlink IO Channel. Can you check what is the difference with the Red output ?
Romain POLETTE
Solution Architect - France Operations
Romain_Polette
Kirk
Posted: ‎2022-05-24 11:28 PM
Hello @welly_xu_quasar ,
It seems that the Smarlink IO Channel is counting during the up -> down edge of the pulse.
Romain POLETTE
J_Travostino
Sisko J_Travostino Sisko
Sisko
Posted: ‎2022-05-10 02:24 AM
Thanks for your question.
I've seen that you added a picture of schematics into the "cover photo" area.
Unfortunately, there, it is not very visible for the community members.
Would you be able to add your picture directly into the post (by replying) and using the "Insert Photos" button? 👇
Insert photo buttonInsert photo button
This would be much helpful to bring you a relevant answer.
Thanks.
Julien Travostino
Power Distribution & Digital forum community owner
Power Products Div.
Romain_Polette
Kirk
1803
Romain POLETTE
Romain_Polette
Kirk
Romain POLETTE
