Zigbee Maximum Distance Limits for PAS400/PAS600/PAS800
Gateways and Energy Servers
  • EcoStruxure Power & Grid
  • Gateways and Energy Servers
  • Zigbee Maximum Distance Limits for PAS400/PAS600/PAS800
Romain_Polette
Kirk Romain_Polette Kirk
117
Guillaume_Evrard
59
Randi_Dolan
46
Joshua_Luzon
Joshua_Luzon Cadet
Cadet
Posted: ‎2022-06-05 07:26 PM
1
3877
Firmware release notes for 1.2.0 and 1.3.1 provided the guidelines for Zigbee Green Power (IEEE 802.15.4) communication in terms of the limit for number of devices connected but not on the distance limitations.
Can you provide the distance limits for ZGP for PAS series devices? Thanks
  • Thumbnail of EcoStruxure Panel Server
View products (1)
  • Commissioning
Thierry_Baudard
Commander Thierry_Baudard Commander
Commander
Posted: ‎2022-06-06 01:02 AM . Last Modified: ‎2022-06-06 01:06 AM
Hello Joshreginal,
  • For PAS400,PAS600,PAS800 in a metallic panel without External  antenna :
Prerequisite: Wireless Output Power is set on Low Level as mentioned in Panel Server User guide (refer to warning page 47 of Panel Server user guide )
Radio Frequency propagation is a physical phenomenon. Therefore, it is identical between a PowerTag Link and an ESXP Panel Server and all the rules explained in the guide wireless PoerTag system guide DOCA0194EN can be applied.
Obviously, it means:
  • a maximum distance of 3 meters between the gateway and the wireless gateway
  • No full metallic partition between them
  • In case of switchboard with non-partitioned contiguous cubicles (example: Prisma/ Okken / Blokset ) : one gateway for 3 cubicles
  • For PAS800 with IEEE802.15.4 External antenna :
It will be possible to connect an external antenna (ref PASA-ANT1) to Panel Server Advanced PAS 800 (not possible with PAS400 / PAS 600 !) to extend the IEEE802.15.4 network outside the switchboard and communicate with devices such as ambient sensor (example: CL110) located outside.
In this case, it will be possible to set the wireless output power on "High" level for the external antenna.
This kind of architecture is very new and some information about wireless performance  will be available in doc NNZ58425 (not yet published) .
Best regards.
Thierry BAUDARD
EcoStruxure Power- Technical Support Expert for Softwares & Solutions
Thierry_Baudard
Commander
Hello Joshreginal,
Best regards.
Thierry BAUDARD
