Join our "Ask Me About" community webinar on May 20th at 9 AM CET and 5 PM CET to explore cybersecurity and monitoring for Data Center and edge IT. Learn about market trends, cutting-edge technologies, and best practices from industry experts.
Register and secure your Critical IT infrastructure
SPP110 pressure transmitters for measuring compressed air pressure
Intelligent Devices Forum
Schneider Electric support forum about all Intelligent Field Devices brands of Sensors, Thermostats, Glass Touch Panels, Valves and Actuators
  • EcoStruxure Building
  • Intelligent Devices
  • SPP110 pressure transmitters for measuring compressed air pressure
CraigEl
Administrator CraigEl Administrator
37
Troy_Wecker
Lieutenant JG Troy_Wecker Lieutenant JG
11
Gary
Gary Schneider Alumni (Retired)
11
MikaelKrantz
Kirk MikaelKrantz Kirk
11
Back to Intelligent Devices Forum
sesa429504
sesa429504 Cadet
Cadet
Posted: ‎2023-02-06 03:08 PM
1155
Hello All.
Could you please give me an information, can we use the SPP110 pressure transmitters to measure compressed air pressure?
  • Pressure Sensors
ThomasSiefert
Janeway ThomasSiefert Janeway
Janeway
Posted: ‎2023-02-06 03:47 PM
Yes, I have used them for that without any problems.
Datasheet
ThomasSiefert
Janeway
Datasheet
PV_DAQ
Ensign PV_DAQ
Ensign
Posted: ‎2023-02-10 10:53 PM
As long as the selected measuring range is greater than the compressed air pressure to be measured.  It requires a 24Vdc power supply and outputs a 0-10Vdc signal.  If it were me, I'd look for a similar pressure transmitter that has a 4-20mA output because 4-20mA output is more resistant to noise pickup and cable distances can be significantly greater than with voltage output devices.  In part it depends on what kind of analog input you have available - voltage or current?
This is a heading
