SHD100-T: Fluctuations in the Relative Humidity readings
Intelligent Devices Forum
Schneider Electric support forum about all Intelligent Field Devices brands of Sensors, Thermostats, Glass Touch Panels, Valves and Actuators
  • EcoStruxure Building
  • Intelligent Devices
  • SHD100-T: Fluctuations in the Relative Humidity readings
CraigEl
Administrator CraigEl Administrator
42
MikaelKrantz
Guinan MikaelKrantz Guinan
11
Gary
Gary Schneider Alumni (Retired)
11
Back to Intelligent Devices Forum
Makarand988
Crewman Makarand988
Crewman
Posted: ‎2022-12-13 05:39 AM
2458
Hi
I am using SHD100-T to measure Temperature & Relative Humidity in return air duct along with ASB-36.
I was frustrated because of too much fluctuations in relative humidity readings, where as Temperature reading was very stable.
Initially I thought it is because of EM interference of AHU motor cables, hence I changed the sensor cable route (and used twisted pair, shielded cable). I did the wiring of the ASB-36 as per its installation sheet.
Also added threshold of 1% in input configuration. but there was no improvement.
I also tried by replacing the sensor with new one, but it didn’t work.
I observed these fluctuations when I increse the Fan speed.
At last, I used the same sensor by removing its metal cap, and I didn’t expect it, but surprisingly the problem solved. And Now I am getting stable readings.
afteraftersensorsensor
Now I am curious to know the purpose of this brass metal cap, is it just meant for the protection of sensing element ?
Are the flucutions in the RH readings is the because of turbulent air flow in the return air duct ?
Will it give wrong readings if I used the sensor without cap ?
What is the correct location to mount the duct sensor (sidewall or top) ?
  • Temperature Humidity & Air quality Sensors
Ted_Roman
Picard Ted_Roman Picard
Posted: ‎2022-12-20 05:34 PM
@Makarand988
I am not familiar with this specific device but my guess is your fluctuations may be due to ground reference. Check out this web help topic.
https://ecostruxure-building-help.se.com/bms/topics/show.castle?id=11941&locale=en-US&productversion...
A few comments:
  • disassembly of field devices is generally not recommended unless following manufacturers documentation for repair
  • Mounting on side or top of ductwork is is usually acceptable for most devices but I prefer sidewall in middle of airstream. While mounting on bottom can lead to condensation entering device and damaging it.
  • I believe the brass cap is a part of the sensor and required for proper operation probably to diffuse air as it enters the sensing element . The datasheet calls it a filter assembly.
Best of luck,
Ted
ThomasSiefert
Spock ThomasSiefert Spock
Spock
Posted: ‎2023-02-06 03:52 PM
Hmmm, it would be interesting so see what would happen if you connected the tip to ground.
Ted_Roman
@Makarand988
A few comments:
Best of luck,
Ted
ThomasSiefert
Spock
