SE8350 Wiring Connection?
Intelligent Devices Forum
Schneider Electric support forum about all Intelligent Field Devices brands of Sensors, Thermostats, Glass Touch Panels, Valves and Actuators
  • EcoStruxure Building
  • Intelligent Devices
  • SE8350 Wiring Connection?
CraigEl
Administrator CraigEl Administrator
42
MikaelKrantz
Guinan MikaelKrantz Guinan
11
Gary
Gary Schneider Alumni (Retired)
11
Back to Intelligent Devices Forum
Jikku
Ensign Jikku
Ensign
Posted: ‎2023-02-02 12:42 AM
1633
I have an FCU with Analog cool type and on/off heater which has to be controlled with SE8350 TH.
Can I connect in BO 8?
  • Thermostats
dano_
Lieutenant dano_ Lieutenant
Lieutenant
Posted: ‎2023-02-03 02:34 AM
hi,
Yes, SE8000 range can be simply modified by additional scripting feature.
By default, by internal application of SE8000, BO8 is used an auxiliary output for reheat.
However, you can select BO8 Aux.Config as default, but Operation Sequence should not use rht, just only  "Coll/heat" mode should e selected
Then you can create short script which activates BO8 based on value from PI regulator output [1]:
BO8 Auxiliary - Binary Output - instance 98
PI heating demand - Analog Output - instance 21
eg [2].
if ME.AO21>10 then ME.BO98=1
if ME.AO21==0 then ME.BO98=0
[1] https://ecoxpert.se.com/search?documentUUID=053ba32c-953c-4783-aa55-7bb26b26a507&title=SpaceLogic%20...
[2] https://ecoxpert.se.com/search?documentUUID=e5be18d0-009e-42d6-9793-8b1dd3ff58ae&title=Lua%20Custom%...
dano_
Lieutenant
hi,
eg [2].
