Join our "Ask Me About" community webinar on May 20th at 9 AM CET and 5 PM CET to explore cybersecurity and monitoring for Data Center and edge IT. Learn about market trends, cutting-edge technologies, and best practices from industry experts.
Register and secure your Critical IT infrastructure
EPP 302
Intelligent Devices Forum
Schneider Electric support forum about all Intelligent Field Devices brands of Sensors, Thermostats, Glass Touch Panels, Valves and Actuators
  • EcoStruxure Building
  • Intelligent Devices
  • EPP 302
CraigEl
Administrator CraigEl Administrator
37
Troy_Wecker
Lieutenant JG Troy_Wecker Lieutenant JG
11
Gary
Gary Schneider Alumni (Retired)
11
MikaelKrantz
Kirk MikaelKrantz Kirk
11
Back to Intelligent Devices Forum
mohamedmorsi
Ensign mohamedmorsi
Ensign
Posted: ‎2023-03-10 08:46 AM
1670
EPP 302
how can i set EPP302 pressure sensor for first use at site (i made all installation instruction however the sensor gives not accurate readings
  • Pressure Sensors
MikaelKrantz
Kirk
Posted: ‎2023-03-12 10:50 PM
1656
Are the DIP switches set correct according to your application?
mohamedmorsi
Ensign mohamedmorsi
Ensign
Posted: ‎2023-03-15 06:04 AM
In response to MikaelKrantz
yes
Troy_Wecker
Lieutenant JG
Posted: ‎2023-03-16 09:42 AM
I reached out to the product support team and here is the response to your inquiry:
There is no special setup for first use besides what is written in the install sheet.
Which output mode is set?
What range is set?
What readings are expected?
What readings is the EPP302 reporting?
MikaelKrantz
Kirk
Posted: ‎2023-03-17 12:36 AM
Want to add to that list, what power supply is used, and what voltage do you have at the sensor?
Replies 4
MikaelKrantz
Kirk
1657
mohamedmorsi
Ensign mohamedmorsi
Ensign
yes
Troy_Wecker
Lieutenant JG
What range is set?
MikaelKrantz
Kirk
This is a heading
