what could cause cooling redundancy n+7?
  • EcoStruxure IT forum
  • what could cause cooling redundancy n+7?
124
110
65
Back to EcoStruxure IT forum
Posted: ‎2020-07-03 03:53 PM . Last Modified: ‎2024-04-08 12:49 AM
849
Dear expert,
We have this rack in DCO showed cooling redundancy n+7, this should not be right. What does it mean and how could we fix this?
Thanks ,
Ziqiang
(CID:118001832)
  • Data Center Operation
849
Hi Ziqiang,
The cooling redundancy for a rack indicates the number of cooling units that can fail and still keep the airflow state of that rack OK. The following page contains the definitions: Cooling Redundancy
As far as I know, cooling redundancy is part of the 2D cooling calculations (and not a user defined parameter).
Kind regards
(CID:118001864)
Replies 4
850
Hi Ziqiang,
Kind regards
(CID:118001864)
Hi Jef,
Thank you. Is there any place I can check which cooling units could affect the rack?
Best Regards,
Ziqiang
(CID:118001907)
Hi Ziqiang,
Right click on a rack, and select Simulate Impact, that should display a list of equipment (including the cooling units).
Kind regards
(CID:118001974)
Posted: ‎2020-07-03 03:53 PM . Last Modified: ‎2023-10-22 09:38 PM
