Posted: 2020-07-03 06:51 AM . Last Modified: 2024-04-08 04:22 AM
HI
How can i delete virtual sensors in Data Center Expert Version 7.2.0 ?
I can't delete that ... I can just remove from map but when i want add new devices it's not posible because virtual sensor tenure my lisense... please help me
(CID:108827967)
Hojjat,
Virtual sensors do not use licenses within StruxureWare Data Center Expert. It will add to the device count in the status bar in the lower right-hand corner of the client, but it will not use a node within your licensing.
To edit/delete virtual sensors (devices):
Cory
(CID:108827970)
Hojjat,
Cory
(CID:108827970)
Posted: 2020-07-03 06:51 AM . Last Modified: 2023-10-22 09:38 PM
