Posted: 2020-07-02 05:33 PM . Last Modified: 2024-04-09 02:16 AM
I am trying to figure out a way to take 16 network connections from blades in a chassis and consolidate them into 4 ports on the chassis that act as one pipe. This same task could be accomplished by having an option for a switch that has the option for specifying up-link ports in addition to the regular ports, or having the option to split one network cable into multiple cables and vice versa. Do you know if there is a way this can be accomplished in the software today? If not, are there plans to try to implement something like this in the future?
Thank you,
(CID:104174416)
Hi Justen,
Today DCO does not support multiple network connections aggregated into one (or single cable plugged to multiple ports as you explain).
May I ask you the customer name in order to add it to the existing feature request?
Guillaume
(CID:104174485)
Posted: 2020-07-02 05:33 PM . Last Modified: 2023-10-31 11:41 PM
